Originally Posted by tendency
do i really need to replace the cam/crank seals if they're not leaking? not replacing those would make the job much more tempting for me to tackle.
Thats what I did and now their seeping a bit only 15k miles later. But the way I look at it itll be easier the second time around, especially since now that ive done the seals on another camry.
The crank seal is really easy. The oil pump isnt to bad, you might need a new rotor since it wears a hairthin groove in itself. Camshaft is sorta trick since you need to remove the cam pulley.
You need a air gun as well, itll save you so much thinking vs trying to take it out with some stone age method.
