First check to see if the cv joint is clicking by making tight turns in an empty parking lot. If you hear clicking then you
have to get rebuilt or new halfshafts.
Rebuilt of OEM halfshafts and new aftermarket ones now carry lifetime warranty. So take your pick. Some prefer dealer parts, that's fine too, but those do not carry lifetime warranty.
As far as rebuilding your halfshaft it does take time to carefully clean the needle bearings and put everything back. Autozone should have the special clamp pliers in their free loaner tool program. I would disassemble the outer joint, but that takes a puller or brass hammer. And you need to torque the axle nut to spec or risk damaging the wheel bearing later.
Originally Posted by oldtruckluvr
I have a 92 Camry 4cyl. While replacing brake pads, i noticed my drivers side cv boot was split in half. Are there any step by step guides to replacing the boot? Any pictures? Also how much of a pain is it to do and how long does it usually take? any help/tips would be great, thanks!! Is it safe to drive while before I replace the boot?
