Originally Posted by camry94v6xle
...might be issue with the Car Alarm system or the wiring of the car...
My questions are:
1. Is your alarm a factory alarm or was it installed after new?
2. Have you/a mechanic checked the headlight relay?
I asked about the alarm because if it has a starter-interrupt (sometimes known as starter lockout) the alarm could indeed be the problem!
I've mention this in other threads....
I personally hate using the starter interrupt feature, and haven't installed one in any of my cars since they were first introduced years ago. The reason is because to install it, you need to cut the main (usually yellow) power wire going from the ignition switch to your starter. Then, if your
alarm ever malfunctions, your car won't start! It won't start and won't crank/turn over because the power from the switch, instead of going directly down that wire to the starter relay, has to detour into the alarm, then go through some circuits and back out, then back to the main yellow wire. If something in your alarm fries, the power won't go back to the starter relay.
But before I continue explaining this proven theory, I want to make sure you have a starter interrupt, especially if the alarm didn't come in the car from the factory.
As for the starter relay, it is on the lower right hand side of your fuse panel under your hood, located on the driver's side in front. The starter relay is closest to the left headlight in the forward box. Standing beside fender looking down, it will be the box on left, and the starter relay is closest to the fender and all the way to the front of the box near the angled corner.
As for the headlights, not really sure what to say about those right now other than check the headlight relay too.
