coolant leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-17-2010, 04:22 PM   #1 (permalink)
akhoundog's Avatar
View akhoundog's Photo Gallery
coolant leak
95 2.2 with about 100k miles.
over the past few months Iv noticed my coolant reservoir would slowly go down over a month, from the full line to low in about a month (~1200 miles ish).
today while mounting up my winter wheels i noticed a table spoon sized puddle on the ground and found this, it looks like the gasket or seal on the water pump??
I had the timing belt, water pump, pulleys ect replaced a little over a year ago.
anybody know what the issue is? i hope it isnt the pump.
akhoundog is offline   Reply With Quote
Old 11-17-2010, 04:40 PM   #2 (permalink)
Chemist at Chevron
Gameroom cash: $315485
View bdy0003's Photo Gallery
Can't say for sure where its leaking from...but do a wipe down and dry everything off. Turn on the car to see where the leak comes from. Maybe then you'll know what part to replace or you can give us an update.
95 Camry LE I4 195k
bdy0003 is online now   Reply With Quote
Old 11-17-2010, 04:45 PM   #3 (permalink)
akhoundog's Avatar
yeah, unfortunately i dont have time to find it now but it looks like the two hoses coming from the pump. i need to see if there's a seal kit there.
Old 11-17-2010, 04:49 PM   #4 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
looks like the waterpump by-pass gasket might be going bad
http://www.partsgeek.com/gbproducts/...ek+Google+Base
G3059-56768 o-ring at water bypass pipe
Old 11-17-2010, 04:53 PM   #5 (permalink)
akhoundog's Avatar
yeah i just found the gastet and an o-ring for that area.
there are only a buck each so ill get them today. could a stuck thermostat cause this?
Old 11-17-2010, 04:53 PM   #6 (permalink)
eh, not likely. You would likely see over-heating before a gasket blowing out from a stuck thermostat.
Old 11-17-2010, 04:59 PM   #7 (permalink)
Chemist at Chevron
or could it be the water inlet gasket?? from your picture, the water bypass area is dry...at least from what i see. I could be completely wrong.
95 Camry LE I4 195k
Old 11-17-2010, 05:00 PM   #8 (permalink)
Probably the little O-Ring above the bypass pipe
G3059-56768 o-ring
http://www.redlinemotive.com/store/r...tion=000655037
If your replacing that though, you might as well spend a couple extra dollars and just replace both
Old 11-17-2010, 07:57 PM   #9 (permalink)
akhoundog's Avatar
shucks only had the lower gasket and the big o-ring for the outlet.
the above link looks like the ring i need for $1.07 but that site says 37.00 bucks shipping to alaska.
anybody know another site that may have the o-ring?
thanks for the replys
Old 11-17-2010, 07:59 PM   #10 (permalink)
akhoundog's Avatar
scratch that 34.27 for ground shipping
Old 11-17-2010, 08:00 PM   #11 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
how about $4.96 + shipping.
http://www.rockauto.com/catalog/moreinfo.php?pk=477429
Old 11-17-2010, 08:01 PM   #12 (permalink)
lol Geeze, Do you have a local parts store near you? Ide try there first. Thats a little ridiculous!
Old 11-17-2010, 08:58 PM   #13 (permalink)
Chemist at Chevron
Maybe even a local dealer might be better?
95 Camry LE I4 195k
Old 11-17-2010, 09:35 PM   #14 (permalink)
I don't know, maybe packages in Alaska come on sleds towed by husky dogs.
Old 11-17-2010, 10:11 PM   #15 (permalink)
akhoundog's Avatar
i checked a few places local but not the dealer. i just got it on rockauto for 10 bucks shipped.
thanks for the help!
