Help with Overheating 1997 Camry
I will try and be brief, but I need help. 1997 Camry with 4 cylinder, automatic. Overheated the other night and temp. gauge pegged. With engine still running I opened hood and noticed instantly that the electric fans were not running. Fan problem? Checked fuses and relays best I could. Found nothing. Read on internet that the fan cooling sensor that's on the bottom of the radiator could be bad. Said that if I unplugged it and the fans came on, it was faulty. I unplugged it and the fans came on( If the fans come on that tells me it's not a fuse or relay problem). So I replaced the sensor. Started the car and it overheated and the fans never came on. So I made the fans come on by 2 different ways. One way was by turning on the A/C. The other way was by unplugging that sensor again. By doing either one the fans come on. I do not have to do both.
PROBLEM #1-So basically, the car overheats and the fans never come on by themselves.
So I put in a new thermostat. Car overheats. So I flush entire system. Car overheats. I look and try and see if water pump is leaking. Does not look like it. Water pump does not make noise. Still suspicious of water pump because I do not see a lot of water flow through radiator and when I squeeze top radiator hose I do not feel a lot of circulation. So water pump? Clogged radiator?
Problem #2- If radiator is clogged or the water pump is bad and the car overheats, WHY ARE THE FANS NOT KICKING ON?! Should the sensors not register the car getting hot and at least trip the fans?
Problem#3- More confusing. Now I start the car and it starts to overheat. So, I use my trick of turning on the A/C to make the fans run. They do. But only for a few minutes, then they shut off and the car begins overheating. Why did they shut off?
I have thought about a head gasket. No water in oil, no oil around filler cap, no sweet smelling exhaust, no power loss etc., etc. What is the problem? Another sensor? Any ideas would be great.
Thanks, Jeff
