Ticking - Possible Valve Issue? (w/ video) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-17-2010, 06:01 PM   #1 (permalink)
View agni's Photo Gallery
Hi all,
The car is a '96 Camry LE, 5SFE, with 150,000 mi. I purchased it used at around 140k, and it has always made this rather loud ticking noise. I've poked my head around in the engine bay, used a screw driver, etc. to try to pinpoint the source, and I'm fairly sure it is coming from the valve train. I've checked the valve clearances, and they were all within spec (actually tighter side, though the engine was still slightly warm when I checked them. I did notice that there was some slight buildup/varnish under the valve cover, but nothing too excessive. I've been doing regular oil changes using Castrol and Wix filters. By the way, the noise is not noticeable while driving. It is also noticeably louder when the engine is at operating temperature (as in the video) vs. when it is cold.
Video
Any thoughts?
agni is offline   Reply With Quote
Old 11-17-2010, 06:15 PM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Sounds like my 5sfe. My valves are out of adjustment. May be your issue too
Grab yourself a mechanical oil pressure gauge and install it where your oil pressure switch goes and monitor the oil pressure.
at normal operating temperature it should read 4.3Psi or more at idle
at 3,000 rpm it should read 36 – 71 psi
If you have low oil pressure, it could be related to a bad oil pump, clogged pickup, or your main bearings could be bad on the crankshaft.
Old 11-17-2010, 06:51 PM   #3 (permalink)
Gameroom cash: $114276
View reluctantmechanic's Photo Gallery
love the videos
reluctantmechanic is offline   Reply With Quote
Old 11-17-2010, 11:14 PM   #4 (permalink)
With regard to the valve clearance, I have checked them and all were within spec.
Testing the oil pressure seems like a good idea. I take it low oil pressure would suggest that the camshaft isn't being lubricated enough. Just out of curiosity, what part(s) be making the "ticking" noise if this were the case?
I'll try to get ahold of an oil pressure gage and report back.
I've also heard suggestions that a loose spring on the exhaust camshaft sub-gear can cause a similar ticking noise. Can anyone verify this?
Old 11-18-2010, 01:24 PM   #5 (permalink)
View V65rider's Photo Gallery
When checking the valves, would they get tighter over time from the valve seats wearing? Or would the get looser?
What part of the valve causes the misalignment?
V65rider is offline   Reply With Quote
Old 11-23-2010, 05:40 PM   #6 (permalink)
I finally got around to testing the oil pressure. At idle it fluctuated between 18-19 psi and at 3,000 rpm it stayed steady at 50 psi - so it doesn't seem like oil starvation is the problem. Perhaps I should just consider the noise normal? We've got another 5sfe camry of the same generation that is much quieter, though. I guess it's just more annoying than anything.
Old 11-23-2010, 05:45 PM   #7 (permalink)
Yeah your oil pressure seems to be A-OK.
nah, the noise isn't supposed to be there.
If you really want to fix the problem, have your head machined and re-worked (new valve springs, retainers, clips, valves reseated, etc..)
Your in the same boat as I am. I am going to have an extra head I have re-worked and swap it out with my head thats on it right now.
I adjusted my valves and it still makes the same noise, so that tells me its a problem with the springs or valves themselves
Old 01-01-2011, 05:33 AM   #8 (permalink)
View kydude7's Photo Gallery
I also have this same issue but i figured it was lifters ticking. Gonna try some lucas and see where im at after that.
kydude7 is offline   Reply With Quote
Old 01-01-2011, 09:11 AM   #9 (permalink)
I doubt the lifter buckets are making a tapping noise :
Old 01-01-2011, 11:15 AM   #10 (permalink)
It's more like a tick but i geuss i should check the valve clearance soon then.
Old 01-01-2011, 11:29 PM   #11 (permalink)
View camry6's Photo Gallery
Pull your base pan and grab each connecting rod bottom end and give 'em a wiggle till you find the one with the bad bearing. Yes even though you are sure the noise is coming from the top end, it is very likely at the crank. I've personally diagnosed a '95 5S-FE and an '02 1MZ-FE with noise seemingly from the top end, but both engines had a bad rod bearing.
1993 Toyota Camry V6 LE (200 HP, 195 ft/lbs tweaked) , 430,000 km's.
2002 Lexus GS 430 V8 VVT-i (300 HP, 325 ft/lbs) Luxury with Mark Levinson , 156,000 km's
2006 Lexus ES 330 V6 VVT-i (225 HP, 250 ft/lbs) Premium Luxury, Sport, Navigation with Mark Levinson , 140,000 km's
camry6 is offline   Reply With Quote
Old 01-01-2011, 11:35 PM   #12 (permalink)
Valve seat wear will tighten the clearances, cam/bucket wear will cause greater clearance.
Old 01-02-2011, 06:36 PM   #13 (permalink)
Wow I sure hope not. I was planning on taking off my pan next change to reseal it; would it be as simple as reaching up and wiggling the rods, or would I have to remove the balance shafts and/or oil strainer? (I've never had the pan off) And suppose they are a bit loose; wouldn't I have to pull out the crank and have it machined and install all new bearings? Could I do this all from underneath? Sorry for all of the questions . . . I'm kind of a noob at engine work.
Old 01-03-2011, 08:05 AM   #14 (permalink)
Canada
I don't mean to spell disaster for your engine, but it is possible that it is a worst-case-scenario. The 5S-FE I diagnosed was a few years back and I can't exactly remember what has to come off (besides the base pan of course) to reach the rods. I think you can get at them without removing the balancer shaft assembly, as for the oil pick-up I don't think thats a problem either. You may have to remove an oil baffle shield to get at it. (Maybe a TN member with 5S-FE experience can help out here?) Remember, side play is normal and at this point not important. Play that allows a piston and rod to move up and down independant of the crankshaft is not normal. If the rod bearings are good, they should be snug on the crank journals with no detectable play found using your hands. (except side to side play, that's O.K.) If it does have a bad bearing, then yea, things will get a little dicey, but just keep your mind "wrapped around" the worst-case-scenario. If your rods are in fact good, then yippee! I could be wrong, but I have seen the same type of problem before.
Good luck!
Old 01-03-2011, 08:13 AM   #15 (permalink)
If I were you, I would check your rod bearings as well, before I had a head rebuilt. Could be something in the bottom end, and watching your video, it sounds the same as the 5S-FE I looked at a few years back, with a bad rod bearing causing the noise. I could be wrong, but I have seen it before. Also the fluctuating oil pressure gauge at high RPM looks like oil pressure loss as a loose rod opens and closes the gap between the rod and journal oil port........unless it is vibration causing the needle to fluctuate. Try holding the gauge in your hand while you rev it.
