I just installed a new cat in my Hilux. It was a walker unit, and it, at first appearance, looked symmetrical from front to rear. After initial install, you could see that the flanges were slightly pitched at one end to accommodate the angle of the pipe in front and behind. Although it fit both ways, you could see that the adjacent flanges were not parallel when installed one way. If you unbolted it, and turned it around, the flanges mated exactly as the original.
Don't know if your toyota is the same, but that's how I figured out which way it went, being that there were no markings or instructions.
Good luck.
T.
94 SR5 Extended Cab, 3.0L, 5 spd manual, Spray on liner, Leer Cap (god forbid!), Class 4 hitch w/ 7 pin connector, HD front sway bar, Air Bag Load leveler in rear .....and a 2003 Sequoia SR5
