Damaged Camshaft when removing Seal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-17-2010, 10:27 PM   #1 (permalink)
View ctbale's Photo Gallery
Anyone care to admit if they did the same bone head move I did when removing my 97 4cyl cam seal? I drilled it, (4 times) and nicked the shaft (4 times) Everything was going so well too. I was changing the 4 seals under the timing belt. One of the lower ones were leaking. I found only 6 out of 7 bolts in the oil pump, the top one was missing. I took a small points file and knocked off the high spots, and blended the nicks with scotch brite. I think they all are outside the inner lip, two are visible, so they are outside the outer seal lip. That metal is soft, and so is me brain! Any links or thoughts? Thanks.
ctbale is offline   Reply With Quote
Old 11-17-2010, 10:30 PM   #2 (permalink)
30 yrs of Car Photography
hairball's Avatar
View hairball's Photo Gallery
Well, since my last job was as a Cam Grinder, I won't say I've done that. But I will shake my head and wonder why you would mess with the cam when replacing seals. Damn, I hope you didn't do too much damage. But hey, the good thing is that you can get it reground to almost any specs for cheaper than a new cam!
By the way, "Hairball" was a cat of mine.
Since I don't use the "GameRoom", can you just send me a check?
hairball is offline   Reply With Quote
Old 11-17-2010, 10:33 PM   #3 (permalink)
It was the cam sproket seal I was removing.
Old 11-17-2010, 10:38 PM   #4 (permalink)
hairball's Avatar
Oh, now it makes more sense. No problem though. But did you have to pull your cam out? If that's the case, don't worry. It takes quite a bit to ruin one from just a nick or two.
If you believe you may have ruined anything, please ask my former boss:
http://deltacam.com/camshaftgrinding.php
If you want, you can just call my former boss/still friend Jon (owner) at 1-800-562-5500 and get Jon's opinion (or whoever answers). The only people who answer are folks who have been grinding cams for 30+ years. I only did it for about a year.
Old 11-18-2010, 01:37 PM   #5 (permalink)
You dont have to pull your cam shaft out to pull the cam sproket seal, just pull off the drive sproket
Old 11-18-2010, 04:38 PM   #6 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Dont freak out. Fel pro makes a kit for this. You put a sleeve over the cam and the seal it comes with is a tad smaller.
It happens alot. Dont leave it or it will leak oil like a sieve.
carsrus is offline   Reply With Quote
Old 11-19-2010, 02:58 AM   #7 (permalink)
great tip!! I will check it to see if its leaking, I can pull back the upper belt cover to check it out
