Antenna - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2010, 11:39 AM   #1 (permalink)
View cracker7213's Photo Gallery
3rd Generation Antenna
I'm going to replace my old broken power antenna with a new manual stationary one. I want to disconnect the power to the antenna, is there any harm in just unplugging it and leaving the cable in the car or should I do something else? I'm pretty sure that I will just get a manual antenna and plug the antenna cord form the radio straight into it.
Thanks everyone for your help. I tried searching for this but I couldn't find anything specific to my needs. Thanks.
cracker7213 is offline   Reply With Quote
Old 11-18-2010, 11:43 AM   #2 (permalink)
30 yrs of Car Photography
hairball's Avatar
View hairball's Photo Gallery
Yes, you can just simply unplug that wire but it would be a good idea to wrap the end terminal with electrical tape just to be safe. As for changing the antenna, the fun part is always running the antenna wire all the way through the vehicle up to the stereo. But it can be done.
By the way, "Hairball" was a cat of mine.
Since I don't use the "GameRoom", can you just send me a check?
hairball is offline   Reply With Quote
Old 11-18-2010, 11:46 AM   #3 (permalink)
Ok great,
Do you know if this will stop the antenna motor from making a noise every time i turn the stereo on and off?
Old 11-18-2010, 11:56 AM   #4 (permalink)
hairball's Avatar
Yes! It will stop! An easier solution is to just pull the stereo out and disconnect the blue wire (the antenna lead is almost always blue). Then you can just pull the power antenna up manually. By the way, is the stereo original or aftermarket brand?
Old 11-18-2010, 12:09 PM   #5 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
I believe the wire is LIGHT blue.
'07 Honda Ruckus Big Bore
Old 11-18-2010, 12:31 PM   #6 (permalink)
hairball's Avatar
Broken how? The actual antenna itself is broken? Or is the motor just bad? Does it always make the noise and not go up? If so, all you have to do is unplug it and pull the antenna up manually and leave it there and you'll be good to go. No sense making the job harder than it needs to be.
I read in another one of your posts that your car is a 96 LE wagon, so here is the stereo wiring colors for that year:
1995-96 Toyota Camry Stereo Wiring:
Constant 12V+: Blue/Yellow
Switched 12V+: Gray
Ground: Brown
Illumination: Green
Dimmer: n/a
Antenna Trigger: Black/Red
Front Speakers:
Left Front (+): Pink
Left Front (-): Purple
Right Front (+): Light Green
Right Front (-): Blue
Rear Speakers:
Left Rear (+): Black
Left Rear (-): Yellow
Right Rear (+): Red
Right Rear (-): White
Old 11-18-2010, 12:37 PM   #7 (permalink)
Safari Wagon's Avatar
Gameroom cash: $213650
View Safari Wagon's Photo Gallery
Here is what I did on my wagon - take the panel off(rear left), and disconnect the multi wire connector that plugs into the antenna assembly. This is the power to the motor. My antenna worked, but I hated how it looks extended 5 feet above my car.... So I turned on the radio, ran back to the antenna and unplugged it about half way up. Now I get fair reception and it looks okay!
Safari Wagon is offline   Reply With Quote
Old 11-18-2010, 12:40 PM   #8 (permalink)
Freakin Scooters
It would be behind the rear RIGHT trunk side carpeting if he has a sedan or coupe.
Old 11-18-2010, 12:51 PM   #9 (permalink)
hairball's Avatar
This previous post should help you a lot:
DIY: 1996 Camry Power Antenna Replacement Procedure
Old 11-18-2010, 01:32 PM   #10 (permalink)
95 Camry V6LE
View allanlaw's Photo Gallery
Thumbs up
I did this almost 10 years ago - no problems since.
allanlaw is offline   Reply With Quote
Old 11-18-2010, 03:57 PM   #11 (permalink)
Thank everybody for all the help.
I went to Toyota today to get a new grommet, they wanted $20! eek. So i'm in the process of finding an antenna that will work for my car. To clarify things, the antenna mast is broken off. I want to put a rubber non moving mast on the car. So the eBay search continues.
Old 11-18-2010, 04:04 PM   #12 (permalink)
Freakin Scooters
Click my sig pic for my for sale thread, then click on the words for pictures. They carry antennas like that at autozone.
Old 11-18-2010, 06:06 PM   #13 (permalink)
hairball's Avatar
For a stationary antenna, I'm hooked on Ford's antennas! I love them! Why? Because they are the optimum height (length): 31 inches high. If you ever search any car stereo sites that explains antennas, you'll find that the perfect height an antenna should be for the best FM reception is... 31 inches! In fact, I've put them on other non-Ford cars I had, they're that good. Even if they extend, most Ford antennas only extend to 31". Apparently someone at Ford knew enough or cared enough to set the standard for the company.
Look, I even put an OEM Ford antenna on my 85 Nissan Sentra wagon! The Sentra antenna is usually like my Camry and comes out from the front door/windshield pillar. I didn't like it. So yes, I used a hole saw and drilled through a few layers of fender and fender well, but I got it in! (The picture below was shot the day after I got my new tires & wheels.)
Note the fender-mounted antenna... yep, it's from a Ford!
Dang I miss that car! 3 amps pumping 1200 watts total. THIS car drew stares and crowds!
