1994 Camry Front End Rattling. Help? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2010, 05:41 PM   #1 (permalink)
View MetropolisPt31's Photo Gallery
Question 1994 Camry Front End Rattling. Help?
Hey, all. First timer here looking for your input.
My '94 Camry has developed a rattling sound near the front right wheel. It usually only occurs over bumps and at lower speeds like through neighborhood streets. Unless I hit a bump or an uneven surface, the rattling rarely occurs at highway speeds, while turning, or while slowly going over speed bumps.
Besides the rattling, the car runs and drives exactly the same. (Not like it was a terribly nimble car to begin with.) There is no grinding noise or anything else that may lead me to suspect that it could be an issue with the CV joint/boot/drive shaft/what have you.
What could this rattling be?
MetropolisPt31 is offline   Reply With Quote
Old 11-18-2010, 10:47 PM   #2 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
First suspicion would be the sway bar bushings, second would be the sway bar links. But it could be a bunch of other things too.
BMR is offline   Reply With Quote
