strut replacement on a 92 camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-20-2010, 11:56 PM   #1 (permalink)
View yotaracer77's Photo Gallery
Looking at replacing the struts on my 92 camry V6. I have found a set of tokiko that someone never installed on there 92 ES300. I know that they are the same parts. The tokiko's are inserts and the struts need to be "serviceable" to use. One, how do I find out if my struts are serviceable, and two, I have changed struts, but not inserts so I any help would be great. Thank you for your time.
yotaracer77 is offline   Reply With Quote
Old 11-21-2010, 06:31 AM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Original part # will tell you if they were "serviceable". I doubt the OEMs were. Serviceable struts are built differently to accept inserts. You should also be able to tell from the construction. You can also contact the manufacturer.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 11-21-2010, 12:24 PM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
If you changed struts they may no longer be serviceable. Cartridges are for old times. You have to check the specs on your current struts to find out.
Old 11-21-2010, 01:45 PM   #4 (permalink)
So just run it to a suspension shop and they can tell me what I need or would I need to pull a strut out ?
