Taller Tires for 2000 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2010, 07:06 PM   #1 (permalink)
View TheGreatGrizz's Photo Gallery
4th Generation Taller Tires for 2000 Camry
I recently bought at 2000 Camry and I'm trying to figure out if I can get tires that are any taller than the OEM tires. Thanks for your advice.
TheGreatGrizz is offline   Reply With Quote
Old 11-21-2010, 07:50 PM   #2 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
You can, but why would you? All it's going to do is throw off your speedometer.
'07 Honda Ruckus Big Bore
Old 11-21-2010, 09:06 PM   #3 (permalink)
Gameroom cash: $177655
View deadrx7conv's Photo Gallery
Speedometers are optimistic. Automakers don't want to responsible for your speeding tickets. Usually a tad taller tire gives you a more accurate speedometer reading.
To go a tad taller, just up to width by one size leaving all else the same.
Greatgrizz, what size do you already have?
deadrx7conv is offline   Reply With Quote
Old 11-21-2010, 09:09 PM   #4 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $609731
View Zembonez's Photo Gallery
My Accord and my Truck speedos are right on with my GPS. Taller tires on a Camry are also going to wreck fuel economy.
Zembonez is offline   Reply With Quote
Old 11-21-2010, 09:12 PM   #5 (permalink)
Why would it wreck fuel economy?
We're not at the limit of power so a slightly lower operating rpm should improve economy.
GPS isn't how speedometers are calibrated.
Old 11-21-2010, 09:15 PM   #6 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Well GPS is accurate. Taller tires increase final drive ratio and therefore add to the effort the vehicle needs to accelerate. Mileage is not all about cruising speed.
Give it a whirl. You'll find out the hard way.
Old 11-21-2010, 09:22 PM   #7 (permalink)
I do. Just about every vehicle I've ever owned had taller tires. Only my Bronco needed new front/rear gears to make up for diameter(because I went up 4") and it didn't affect MPG once the gear ratio was decreased(numerically increased).
Like I said before, we're not at the limit of power.
And, GPS is accurate. But, its not how you calibrate a speedometer. Don't forget hills.
Old 11-21-2010, 09:35 PM   #8 (permalink)
2win2rbo's Avatar
Gameroom cash: $156522
View 2win2rbo's Photo Gallery
Yes you can. In ecomodding, it's called "poor man's final drive upgrade." It's beneficial if you are driving mostly in the highway. It's going make the engine work more in the city.
pgmomni, an active Camry member in ecomodder.com and who was once posting here on TN, uses a 6% plus oversized tires since he does mostly highway. He already broke his 35 mpg mark with the front air dam and the lower grill block for winter. He also reached up to around 37 to 38 mpg recently, if I am not wrong.
1993 Toyota Cresta Tourer S JZX90
1988 Toyota Mark II GX71
1999 Subaru Outback 5-speed
2000 Toyota Mark II IR-V
2003 Subaru Legacy BP5 2.0R
2win2rbo is offline   Reply With Quote
The Following User Says Thank You to 2win2rbo For This Useful Post:
Zembonez (11-21-2010)
Old 11-21-2010, 09:36 PM   #9 (permalink)
To understand hills, use an extreme hill. Take your GPS into an elevator. You'll be moving up/down at a speed but what does your GPS read? If you paid attention in geometry class, you'll understand.
Old 11-21-2010, 09:37 PM   #10 (permalink)
Freakin Scooters
Deleted some posts here. Let's play nice gentlemen and stay on topic. No personal attacks per forums rules, please.
Old 11-21-2010, 09:39 PM   #11 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
I'm quite sure my comparisons between GPS and my speedos were not climbing pikes peak. Thanks for the geometry refresher.
Hey OP. Sorry for the nutty thread derail.
A small increase in size would probably not be noticeable fuel economy wise... but I don't think you can hope to increase your fuel economy by increasing tire size.
Old 11-21-2010, 10:39 PM   #12 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
I measured the tires on my 01'. I have about a little over an inch of clearance between the top of the tires on the struts. I have new 205/65-15 Falken ze912 on 15x6 wheels with +39 offset. I think the max you can run is 205/75-15 with is about 1.6 inch taller and with throw the speedometer off by 4 mph. May rub on turns?
Here's a good site to compare sizes
http://www.1010tires.com/TireSizeCal...?action=submit
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is online now   Reply With Quote
Old 11-22-2010, 07:00 AM   #13 (permalink)
Thanks for the response. I have 205/65/R15's now.
Old 11-22-2010, 09:53 AM   #14 (permalink)
215/65/15, 195/70/15, or 205/70/15 are taller.
I don't like 'double' stepping when going taller since 'feel' of vehicle will be different if you're a observant driver.
Also, opens up different brands/types/availability when hunting for cheapest tires on closeout/sale..... So, different sized tire could also be a 'budget' decision having nothing to do with MPG. Would you turn down the neighbors 'free' tires if yours are bald? I didn't!
One thing I noticed is that taller tires seem to last a little longer too.
MPG might not be noticeable but many things affect MPG mildly and we use them. If MPG is the goal, synthetic ATF, PSF, motor oil is a start. Thinner fluids is another. Good alignment, more tire PSI, eco-green tires(no traction low rolling resistance), ... also help.
Miata tire calc is a good tool:
http://www.miata.net/garage/tirecalc.html
Old 11-22-2010, 11:32 AM   #15 (permalink)
Any idea if these sizes will work without scrubbing?
