need to know the name of this broken sway bar component - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-22-2010, 05:28 PM   #1 (permalink)
AKA: KSNIPPY
nivek5sfe's Avatar
View nivek5sfe's Photo Gallery
the manual calls it a "stabilizer end bracket" and ive triend many other similar things while trying to search for a replacement but no luck. i was rotating my tires today and noticed it. if i cant find a replacement or its too expensive ill just weld it
broken
what it would look like together
nivek5sfe is offline   Reply With Quote
Old 11-22-2010, 05:43 PM   #2 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Sway bar link. Under 30$, you probably need to do both sides.
You cant weld parts that move.
carsrus is offline   Reply With Quote
Old 11-22-2010, 06:02 PM   #3 (permalink)
Pvt-Public's Avatar
Gameroom cash: $274350
View Pvt-Public's Photo Gallery
Are those rivets or bolts holding it to the lower control are? If they are rivets it is part of the lower control arm and you will have to get the arm. If they are bolts, the only place your going to get that bracket is at the dealer or junk yard. I really doubt they are available aftermarket.
Pvt-Public is offline   Reply With Quote
Old 11-22-2010, 06:03 PM   #4 (permalink)
AKA: KSNIPPY
nivek5sfe's Avatar
its not the end link thats broken its the bracket that mounts it to the lca. it doesnt move at all so it can be welded.
Old 11-22-2010, 06:06 PM   #5 (permalink)
AKA: KSNIPPY
nivek5sfe's Avatar
its bolted on under the lca.
from the searches ive done that bracket usually comes on the lca so i dont know if i can get just a replacement bracket, which is where you may be right on getting it at a junk yard or maybe a part out.
Old 11-22-2010, 06:12 PM   #6 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
That bracket can be replaced. The same thing happed to mine a while back. Cheapest place to get one is from a wrecking yard. They may even just let you have it free.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is online now   Reply With Quote
Old 11-22-2010, 07:16 PM   #7 (permalink)
Gameroom cash: $202300
View zppeacock's Photo Gallery
What year and trim level/motor and I can get you the factory part number.
Edit: Otherwise the factory parts catalog call it Front Stabilizer End Bracket.
zppeacock is offline   Reply With Quote
Old 11-22-2010, 07:20 PM   #8 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
Junkyard or just weld it. Personally I would hit up the junkyard and get it. Probably would be free, as stated earlier.
Looks like you need new end links too...
Chris Crash is online now   Reply With Quote
Old 11-22-2010, 07:23 PM   #9 (permalink)
You could try that, junkyard is a good idea, unless your in the rust belt like I am. If you need the oem part number let me know.
They are around $20 new.
Old 11-22-2010, 07:25 PM   #10 (permalink)
uibalnme's Avatar
Yeah, get a used one, and then add a nice fat weld bead on the inside of the bend to strengthen it. It's odd that these seem prone to failure even in non-rust belt areas.
Old 11-22-2010, 08:01 PM   #11 (permalink)
redneck engineer
lemegacool's Avatar
Gameroom cash: $233405
View lemegacool's Photo Gallery
you have a welder? weld it ----- done!
1994 camry v6 5 speed swapped
holset hx35w rebuild/polishing in progress :P
cardomain: http://www.cardomain.com/ride/3872430
lemegacool is offline   Reply With Quote
Old 11-22-2010, 08:08 PM   #12 (permalink)
AKA: KSNIPPY
nivek5sfe's Avatar
yeah that would be great. its a 95 le 4clyinder
i tried looking in the shop manual for the name and it came close
yeah i live in the south so no rust belt here
im almost certain that ive been driving with it like this for about a year. ive been hearing it clanking around when i enter my driveway but have just been ignoring it.
Old 11-22-2010, 08:11 PM   #13 (permalink)
A camry n00b
peshwa's Avatar
Gameroom cash: $257859
View peshwa's Photo Gallery
I ran into the exact same problem. Its not a sway bar end link. Those are end link brackets, a dealer only item.
IMHO go to a car salvage yard, like Pick N Pull is in California and remove the bracket.
At the dealer a bracket will run you $25 (not sure). At the pick n pull its not more than $5 or less.
I say dont waste your time into welding and all the crap, take your wrench, a good breaker bar, PB blaster soak it for some time on the salvage yard camry, 17mm and 19mm/21 mm sockets should help you.
All the best!
1995 Camry DX L4 178,6XX miles and counting each mile.... acquired 05/25/2007 at 129K miles
2004 Mazda6 I4 5-Speed Manual 115,500 miles acquired 01/21/2011 at 109,XXX miles
peshwa is offline   Reply With Quote
Old 11-22-2010, 08:17 PM   #14 (permalink)
AKA: KSNIPPY
nivek5sfe's Avatar
All the best!
this is what ill probably end up doing. theres a salvage yard close to here that i can just get one out of.
Old 11-22-2010, 08:32 PM   #15 (permalink)
Gameroom cash: $148300
View SilverSoarer's Photo Gallery
You will also have to replace the sway bar endlinks - the part that looks like a 'dogbone'
I have 2 (brand new endlinks in shrink wrap) for the 92-96 Camry for $25 + shipping - these come with new castle nuts and anti-seize.
Often the old nuts are destroyed when removing endlinks.
PM me for details.
SilverSoarer is offline   Reply With Quote
