Well there's 2 V6's. The 1MZ-FE (94-96) and the 3VZ-FE (92-93). The 4cyl 5S-FE covers 92-96. The 3VZ tends to have head gasket issues around 200k miles, but thats an preventative maintaince easy fix. The 1MZ has apparently had minor sludge problems. The 5S is VERY unforgiving if you let it run low on oil.
But any engine in any car is gonna have quirks. All the Camry engines are SOLID... IF you take care of them.
'07 Honda Ruckus Big Bore TOTALED: '03 Ford Expedition Eddie Bauer 4x4 5.4L, '96 Camry LE 5S May '10: '11 Sienna V6 XLE FWD 8-pass. July '10: '06 Matrix XR Auto FWD Oct. '09: '05 RAV-4 L 4WD
The Following User Says Thank You to LynchburgCSI For This Useful Post:
Less moving parts, less weight to haul around, less power but cheaper to operate in the long run. Also, is easier to work on IMO, and parts are a little cheaper as well
But, just like Mr Perkins said - the key to longevity with these motors is proper maintenance
1996 Toyota Camry 5SFE 5-spd 329.9K - UNDER REPAIR
1997 Honda Civic 1.6 5-spd - 183K and 27 MPG average - Dependable DD and *small* family car
1991 Acura Integra 1.8 5-spd - 241K and 28MPG average - I'm game for a simple LS Vtec swap now...
The Following User Says Thank You to N/A Camry Sleeper For This Useful Post:
All the gen 3 Camry engines will last.!. I would think the I4 would last longer and be cheaper easier all around. But My opinion may be swayed a bit. I love my 5S..
The mainstay Toyota engine is the 4-cyl. It's gotten the most attention and is the most reliable. The larger their displacement/cylinders, the less reliable. The 4-cyl won't have the horsepower, but it has the fuel economy (I'm sure gas prices are going back up).
These are all old engine designs of course. New designs are moving toward turbo charging smaller engines and using direct injection. And excellent examples of these are VW 4-cyl engines and the newer Ford eco-boost engines.
The Following User Says Thank You to JohnGD For This Useful Post:
The gen 3 1MZ-FE does have sludge issues, but you'd have to be much more abusive and change your oil more infrequently than a gen 4 1MZ-FE to get the same amount of sludge IIRC, in the gen 4 1MZ, piston heads ran warmer, and Toyota removed the oil cooler (which they also did for later 5S-FE I think??)
+1, we are going to see 4$ a gallon again, and very soon. But honestly, I've driven a 5S-FE, and I'd rather pay the extra fuel money, even if gas does go to 4$ a gallon...
1995 Toyota Camry V6 LE-6M1 250K Miles, Fun Car
1997 Acura RL-Gone
2007 Acura RL SH-AWD, Technology Package, Opulent Blue Pearl- Fun Car/Daily Driver
azcat90. Here is an answer which you I believe are looking for. Both are truely equally reliable. I have a 1MZ-FE with 181k on it and I redline the thing everyday once the engine is warm. I also properly maintain it. Which I assume you do as well. The 92 v6 you had was a 3VZ-FE which is a cast iron block and is heavy. You know the gas mileage is gets. The 94+ has the 1MZ which is lighter because is an aluminum block, I do not know the exact weight difference. Yes the I4 is easy to work on. But once used to your engine and you do it once put it back together right then you really don't care.
Mileage wise: They get the same! No matter what your driving pattern is. For each driver they are the same. The V6 has more power which means lower rpms to get to the wanted speed. I have gotten 30+ mpg on my 1MZ on highway. I get 25 on city. (WITH OLD AUTOMATIC TRANS) So this gas mileage thing is a bunch of fooie.
Repair Costs: I don't know about that either. Parts Cost wise is about the same. Like for example axles. They are different, but cost the same. Soooo..... I mean unless like you throw a rod its the same. But if something that big happened you would most likely be looking for another car.
This sludge thing: I haven't heard of it for me. But there was some difference with the 94-95 1MZ and the 96. I have the 96. I don't know what the change is but like I said this is the first time of me hearing of it.
And finally azcat90, you are used to the power of a V6. You are going to get into a I4 like I did and just say to yourself "this isnt right. The car feels....Wrong"
Hope this helps.
2009 EX-L V6 6Spd MT w/Nav (stock for now)
1996 XLE V6 Camry, KSport GT Pro 9/7, TRD RSB, E153 5spd conversion, Gen 3 front end conversion, OBX Headers, Megan Cat Back, TRD M62 Supercharger
Supercharger whine > ex girlfriends whine http://www.cardomain.com/ride/3329124
The Following User Says Thank You to camrtm3 For This Useful Post:
I've read several comments on this board about the 3VZ being much heavier than the 1MZ. I don't know if the engine got lighter but the car got heavier, but here is a quick weight comparison -
1992 Camry sedan LE V6 - 3252; XLE V6 - 3285
1996 Camry sedan LE V6 - 3241; XLE V6 - 3274
An eleven pound difference (0.24% difference) does not seem that significant....
The 3VZ is heavier than the 1MZ... but on a FWD 3200 lbs car, it REALLY doesn't matter. Plus the weight over the driven wheels helps with traction.
