Originally Posted by blaxkinned
I am thinking of dropping the subframe on my 99 Camry V6, anyone have tips, tutorials, diagrams that would help?
I mainly might be doing a transmission swap.
Thanks
I think dropping the subframe is easier than lifting the engine - I believe there are fewer steps in dropping the subframe (not having to remove the axles being the biggest). But if you are going to replace the trans, your axles are coming off either way. I'm also pretty sure the main bolts can't be re-used (and they are maybe 4-6 bucks each)
I did this on a V6 Honda Odyssey, never used an engine hoist - instead, when the main sub bolts were ready to be removed, I placed each side of the subframe on a rolling dolly, making sure I could still access the main bolts - with the subframe resting on the dollys, I removed the bolts, then raised the body off the engine using two floor jacks - I needed about 48 inches of clearance to roll the engine out.
You will have to disconnect the brake lines, so drain as much fluid as you can the night before (oil, brake, coolant, powersteering)...The worst part of this for me was the mess.
Hoped that helped - keep us posted on your progress if you lifted or dropped the engine.
Thanks!
