1999 camry 4cyl MAP sensor location - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-24-2010, 08:13 AM   #1 (permalink)
View ninajoe's Photo Gallery
I cannot locate the MAP sensor. Is it possible that there is no MAP or MAF sensor on some models? I am trying to resolve a 171 error code.
ninajoe is offline   Reply With Quote
Old 11-24-2010, 09:31 AM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
it's on the firewall behind engine. the sensor itself has either blue or red sticker on it. there is also a vacuum line running from bottom of sensor to intake manifold. your 5s-fe car wouldn't run without it. there is no MAF on 5s-fe engine.
Old 11-24-2010, 02:55 PM   #3 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
it will run without it, but it will constantly stall and blow tons of black smoke out the exhaust
Old 11-24-2010, 03:03 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
and you call it running?
Old 11-25-2010, 05:29 AM   #5 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
You forgot some people here happen to be HUMAN. "Running" can mean a lot of scary scary things.
'07 Honda Ruckus Big Bore
Old 11-25-2010, 08:09 AM   #6 (permalink)
View coffee-3000's Photo Gallery
3rd Generation MAP vs MAF
I think the 4 cylinder has a MAP and the 6 cylinder has a MAF.
Cleaning my MAF fixed my P0171 trouble code.
But this trouble code eventually reappeared months later with the misfire trouble code. Maybe they go hand and hand. I had to replace a bad fuel injector to solve my issue.
Let us know how you solve your P0171.
1996 V6 Camry 150K
coffee-3000 is offline   Reply With Quote
