Yeah I could use one soon too. haha. Which part exactly are you replacing? The entire line? Or just part of it? I think an entire one from the slave to master cylinder would be good to avoid that pesky (and broken on mine) connection on top of the trans.
Let me know what price you get and see if they'll lower the price if you get two made. If so, buy two and let me know I'll pay you the difference.
^ I wouldn't use an entire braided line, personally
just replace the one from the transmission to the master cylinder
I don't think the braided lines are still as flex-proof as the actual solid lines. if you're having problems wit the hard lines on top of the tranny, just replace them with over the counter hard brakelines
HaHa
"Life is a deep sleep, of which love is the dream..." Ripped...and the girls are loving it.
whats that block that the clutch line goes into. that block which i speak of is between the slave and the master. closer to the slave. right next to the transmission (or is it on top of the transmission)
That's what I'm talking about, the junction/bracket where my male end is stripped.
You could just measure the threads then send the measures to the company. Then I guess custom make a bracket? Or maybe you can get the soft rubber hose out of the bracket, and slide the SS line in?
that is known as the accumulator, and it's supposed to make the clutch feel a bit softer and "nicer" to use according to some people
I haven't really felt the difference when I bypassed mine...but then again, I'm comparing my fidanza with stage 3 flywheel and braided steel line to bone stock 5-speed camrys
you can run a hard line straight from the soft-line off of the master cylinder to the slave cylinder. theoretically, the best feel you can get is with ALL hardline, but since the motor rocks, there has to be a soft line somewhere around the firewall area (thus, the soft line between off of the master cylinder).
take a look at my swap tip page in regards to replacing the line:
hey, no....the best way is to copy the original set up as much as possible
I ran a hard line from the slave cylinder up past the accumulator, and then had it stick up right around where the original hard line came up to- right above the shifter arms area and pointed up
if you check my thread and picture, the length that I used was a 20" line to go from the slave to above the tranny towards the master cylinder
then get a braided line to replace the soft line that is the exact same length
HaHa
