30mm is the correct size. You can rent a 30mm axle nut socket from Autozone (pn #27053...?) They also have 32, 34, and 36mm. I'm not a 100% sure if it will fit because the wall of those socket are a bit thick. But free is better than buying a tool you would use once in a while.
$7 for a large Craftmans socket isn't too bad but I'm not sure if they make 30+ socket sets.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
