smell from outside through aircon - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-26-2010, 03:00 AM   #1 (permalink)
View sanlen's Photo Gallery
Hi,
I noticed that i now get smell from outside through the aircon of my camry 1998. I am worried there might be something wrong with my car's aircon. I want to fix this.
Could you please advice?
Thanks,
sanlen
sanlen is offline   Reply With Quote
Old 11-26-2010, 06:45 AM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Smell could be A/C lubricant if system is leaking in vent system. Also could be good old mildew in A/C system, usually in the evaporator box. Try an A/C deodorizer that you can spray into the vent system through the recirculation vent while the fan is on. Make sure your evap. drain is not blocked.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
The Following User Says Thank You to Stillrunning For This Useful Post:
doozergreengrass (11-26-2010)
Old 11-26-2010, 09:55 PM   #3 (permalink)
View doozergreengrass's Photo Gallery
I never knew there was such a deodoriser, so thanks! Apparently (in my 95 camry) theres also a filter for the air/con ventilation system behind the glovebox (mine is RH drive). So i'm going to get a deodoriser and filter - every car i've owned has had an odd smell in the a/c...
doozergreengrass is offline   Reply With Quote
