heater problems, and a leak.....
ok my 97 I4 has 113k on it. i put a new radiator in it 3 months ago. The problem is that when at idle, the heater gets cool. but when you are driving at any speed its good and toasty. I dont believe this to be a blend door issue. it seems like maybe there is a coolant circulation problem going on, maybe a clog in the heater core. I flushed it with the thermostat out when the rad was installed. today i flushed it again. I could not find my 10mm wrench to take the thermostat housing off, so i flushed it the best i could. the water ran clear... when i refilled, the rad only took half gallon of antifreeze. i let it run for 15 mins, to normal temp. it stayed there, but the heat didnt get too hot. gonna take it for a run tonite, but im lost here. maybe this indicates my water pump is dying?? not sure why, but the hose coming off the thermostat housing down to the bottom of the rad did NOT get warm at all the whole time the car was running.... the top hose did get hot.....
Something else guys... ive been loosing power steering fluid since i got it in feb. it was just a tiny bit but recently its been leaking more. maybe someone could point me to a thread or something i could start with? I really cant tell where its coming from. i did the fluid change from the DIY thread months ago, it didnt seem to make any diff with the leaking....
On a good note.. i did the LED cluster bulb swap. ordered from superbriteleds.com and got blue bulbs. Man, it looks good, and everyone that gets in my car thinks it looks bad ass!
97 Camry LE 5SFE 135k
94 Corolla 1.6 @ 215K
97 F150 xlt v6 120k
92 Accord 4cyl 127k (totalled 8.4.11 by semi)
