Tire sizes for 2000 Camry XLE V6 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-28-2010, 11:22 AM   #1 (permalink)
View calguy99's Photo Gallery
Hi I am getting new tires for my 2010 Camry XLE V6 the original tires have only 10,000 miles on them and I want to give them to my girlfriend for her 2000 Camry XLE V6. My question is will my stock P215/60R-16 tires fit on her stock 2000 Camry XLE V6 16" alloy rims. Thanks
1978 Corolla Hatchback
1987 Camry LE
1992 Camry LE
1993 Camry LE
2010 Camry XLE V6
Are Hybrids Hype? >>>> http://spectator.org/archives/2012/0...a-civic-lesson
calguy99 is offline   Reply With Quote
Old 11-28-2010, 11:28 AM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Tire Size Comparison
Specification--Sidewall----Radius--Diameter---Circumference---Revs/Mile---Difference
205/60-16 -----4.8in-----12.8in----25.7in---------80.7in----------785----------0.0%
215/60-16 -----5.1in-----13.1in----26.2in---------82.2in----------771----------1.8%
Tire should fit, it will just be a little taller
EDIT:
I AM INCORRECT. THE 2000 CAMRY IS 15" RIM. THIS TIRE WILL NOT WORK
Old 11-28-2010, 12:43 PM   #3 (permalink)
Pvt-Public's Avatar
Gameroom cash: $274350
View Pvt-Public's Photo Gallery
Everything I can find says the 16" alloy wheel was standard on the 2000 XLE V6. They will fit but the speedometer/odometer will be off by 1.84% (speedo reads 70mph, actual speed is 71.29, odometer says you have gone 70 miles you really went 71.29 miles) Perkins has the dia. and % difference correct.
Pvt-Public is offline   Reply With Quote
Old 11-28-2010, 12:47 PM   #4 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $908127
iTrader Score: 59 reviews
^^^^What he said!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
eyeball96 is offline   Reply With Quote
Old 11-28-2010, 01:22 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
R16 wheels were offered as an upgrade package or a standard OEM on some trims (or as an option).
my 2002 Solara SLE V6 came with OEM 205/60/16 wheels/tires. other factory setup was 205/65/15 (this I got on my 2000 solara SE i4).
they are both considered as stock.
there is a nice tire size (including plus sizes) calculator for comparing:
http://www.1010tires.com/tiresizecalculator.asp
there was also another one showing actual pictures of how selected tire would look like on selected rim, but cannot find that now.
Old 11-28-2010, 01:24 PM   #6 (permalink)
抵抗は無駄です
fenixus's Avatar
are you saying I should correct my MPG calculation by +1.84% on traveled distance (using 16'' rims) ?
huh, interesting, never thought of that.
