thermostat OE manufacturer? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-28-2010, 10:55 PM   #1 (permalink)
View tendency's Photo Gallery
anyone know who makes the OE thermostat on gen 4 camrys? thx
tendency is offline   Reply With Quote
Old 11-28-2010, 11:03 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Kuzeh
Old 11-28-2010, 11:04 PM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
i suggest getting an OEM from any dealer online at a discounted price. not worth it to try any aftermarket on that one. price difference shouldn't be vast between online OEM and any aftermarket.
... edit ...
or Try what JohnGD says
Old 11-28-2010, 11:10 PM   #4 (permalink)
Right, there are plenty of online dealers selling parts cheap. Mail order ahead of time.
Here is an example of an aftermarket thermostat that I won't use (for either domestic or import cars).
$6.04. Light duty construction, lack of jiggle valve and gasket (~$1.50).
http://info.rockauto.com/Stant/Detail.html?13758.jpg
However, they also offer an OE style, which if I have to I would try:
$11.51. Heavier duty construction, with jiggle valve and gasket.
http://www.rockauto.com/catalog/moreinfo.php?pk=1145694
This one looks close to the Kuzeh. I'm not sure if it's a rebox or not. But they can change supplier any time.
Old 11-28-2010, 11:24 PM   #5 (permalink)
do i need to get a new gasket when i replace it as well?
Old 11-28-2010, 11:40 PM   #6 (permalink)
Yes. Highly recommended, because you don't know if the old one got pinched when a mechanic installed it or took a set.
That said, I've reused many gaskets without problems, not that I'd recommend it, because you'll need new coolant if you need to go back in. And that's expensive vs $1.50 gasket.
