dash board light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-29-2010, 10:25 AM   #1 (permalink)
View sub0's Photo Gallery
dash board light
Good day,
For a 1994 Camery V6Le. The dask board usually have light under the Radio for heat control...etc and also where you switch to drive close to the driver seat. Is that very hard to locate the light bulb and change it ?
Thanks !
sub0 is offline   Reply With Quote
Old 11-29-2010, 03:40 PM   #2 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
I'm having a hard time understanding your question. Yes, the HVAC controls should light up. There is also a light for the small pocket underneath of the cup holders. And the shifter indicator in the center console should also light up (PRND2L).
'07 Honda Ruckus Big Bore
Old 11-29-2010, 07:52 PM   #3 (permalink)
The light underneath of the cup holders got burn out and the shifter indicator in the center console also got burn out. The under the radio there are a roll of bottom for select
the heater/fan to blow air to the floor/leg or to windshield...etc the light goes off too.
Maybe is the same light or 2 or 3 of them.
Thansk !
Old 11-29-2010, 09:00 PM   #4 (permalink)
Freakin Scooters
Yes, those are all the locations that I just listed off.
Old 11-30-2010, 12:10 AM   #5 (permalink)
Sorry, I just don't get it. I post the area that should have light and the same you quote prev. but now the light got burn out.
I was wonder is that hard to replace the light bulb and possible how ?
Thanks !
Old 11-30-2010, 12:51 AM   #6 (permalink)
Freakin Scooters
You'll have to disassemble your interior basically. It's not too bad.
DIY: Gen 3 "D" Bulb replacement That DIY should allow you to get to certain areas of the HVAC controls.
The shifter surround on the center console also pops off the same way as the U-trim around the radio. Stick in a flat head and pray from the bottom. It pops right off. I can post more info if needed, but it's fairly self explanatory.
