ignition help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-29-2010, 10:28 PM   #1 (permalink)
View derickstephens's Photo Gallery
ignition help
I have a 94 camry 5sfe that is having starting problems. The main problem is that at first the starter would engage most of the time, now nothing. Checked solenoid, is good. All lights on the dash are good, but no turn over. I am sure it is between the ignition switch, neutral safety, and the starter relay. Can anyone tell me which wires to check on these, and their respective colors. That would be most helpful.
Any help would be helpful.
Thanks
derickstephens is offline   Reply With Quote
Old 11-30-2010, 01:54 PM   #2 (permalink)
View djb2's Photo Gallery
The starter relay is known to fail at this age.
It's pretty easy to remove and inspect -- do a search. You can clean the pitted contacts to get it working temporarily, or replace the the copper pieces for about $20 to get a long term fix.
djb2 is offline   Reply With Quote
Old 11-30-2010, 07:58 PM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
If it's the starter solenoid contacts they're cheap, see this DIY:
Starter Solenoid Contacts Replacement DIY (2000 I4)
