Thank You all for the advice.
Recently I replaced the rear valve cover gasket on both VCs along w/ the PCV valve at the rear bank VC. I think the PCV valve would not be an issue. Well unless I got a bad PCV from Toyota.
Regarding the air coming/out into the crankcase, let me confirm my understanding on a perfectly fine running 1MZFE:
So the front valve cover nipple above the oil filler cap is to let the air IN from the intake duct (after MAF) aka breather.
And the rear VC hole (w/ PCV ) is where it lets the air OUT (if there is any blow by) into the intake manifold/ SC if equipped.
Originally Posted by dorifuto.boi
can u check ur pcv valve in the back ? if thats also blowing out air, then u probably have blown rings letting all the compressed air in the combustion chamber into the crankcase... cause theres no where else that all the air can be comming from
Last time I was putting back the VC together, I did not notice any air coming out from the hose connected to the PCV
So like what Jason said, unless my brand new PCV is BAD, there seems to be a blockage on the rear VC due to some carbon build up and if I could remember, I did see carbon build up on the rear VC.
Originally Posted by Jason.MZW20
You may need to remove the rear bank's valve cover, remove the PCV valve, and allow a strong solvent to soak in the PCV baffle area. My 72k mile 1MZ had quite a few deposits (mainly carbon buildup) come out from the baffle area. Since the baffles are riveted in place, they're not removable.
I suspect this is the issue (I hope)
I checked the front VC like I said on the first post by blowing smoke into it and saw the smoke coming out but I DID NOT (damn!) check it when I had the rear VC open.
and about the venting the pcv system, don't vent it to the atmosphere. u'll get deposits all over your engine bay. use an oil catch can. the oil catch can goes between the pcv valve and the supercharger... the pcv hose connects the pcv valve and the back of the supercharger so u need to disconnect that hose and stick the oil catch can in the middle. don't use a breather filter...
about ur cel, fix the misfires first. then fix ur pcv system, then clean ur maf to see if the lean code goes away.
and i don't understand the misfires. cyl 2 and 6 are both on the front bank. so if the coils are bad, it'll also misfire on the two rear cylinders that are connected to the coils on cyl 2 and 6...........
If I were to put catch can then it would at the hose that comes out from the PCV valve right at the rear VC.
When I cleaned the MAF, I did not have any lean CEL so hopefully it remains like that for a while.
It might be poor connection to the Cyl 2 and 6 from the coilpacks or maybe I have a fouled/bad spark plugs.
The weird thing is that the car w/ the SC drives perfectly fine.
BTW, I have a second car so the Solara sits in the garage until I can remedy this problem.
I'll post back w/ updates whenever I open the S/C again in the next few days
Thanks again for the help guys!
