J1850 VPW Protocal for 96 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-30-2010, 12:49 PM   #1 (permalink)
View coffee-3000's Photo Gallery
3rd Generation J1850 VPW Protocal for 96 Camry
Can anyone verify that the 96 Camry uses the J1850 VPW ( Variable Pulse Width) OBD2 protocol ? It is tough to find this on the web for some reason.
1996 V6 Camry 150K
coffee-3000 is offline   Reply With Quote
Old 11-30-2010, 01:06 PM   #2 (permalink)
2001 Camry XLE 1MZ-FE
View ajkalian's Photo Gallery
As a rule of thumb, GM cars and light trucks use SAE J1850 VPW (Variable Pulse Width Modulation). Chrysler products and all European and most Asian imports use ISO 9141 circuitry. Fords use SAE J1850 PWM (Pulse Width Modulation) communication patterns.
On 1996 and later vehicles, you can tell which protocol is used by examining the OBD II connector:
J1850 VPW--The connector should have metallic contacts in pins 2, 4, 5, and 16, but not 10.
ISO 9141-2--The connector should have metallic contacts in pins 4, 5, 7, 15, and 16.
J1850 PWM--The connector should have metallic contacts in pins 2, 4, 5, 10, and 16.
This has more info....
http://www.obdii.com/connector.html
2001 Camry XLE, 6cyl, 1MZ-FE, 91,000 miles.
ajkalian is offline   Reply With Quote
Old 11-30-2010, 01:40 PM   #3 (permalink)
Going against the rule of thumb
The guy at obd2-2.com says that the 1996 Camry is an exception to the rule of thumb. He tells me that it uses the J1850 VPW protocol.
The only thing I can find on my own is that the 1996 Corolla and 1996 Tacoma use the J1850 VPW.
1996 V6 Camry 150K
Old 11-30-2010, 02:13 PM   #4 (permalink)
I found this in a Gen 3 Camry manual, but I can't say for sure if it applies to your specific 1996 model.
Old 11-30-2010, 03:05 PM   #5 (permalink)
Great. Thanks !
Thanks AjKalian. This is great. It looks like the ECM communicates using the J1850 VPW Protocol. And the physical connector ( or plug ) is the SAE J1962 connector.
1996 V6 Camry 150K
