Originally Posted by fenixus
have you tried turning O/D off to see if same thing happens?
by looking at RPM it seems the tranny slips a gear or upshifts for a brief moment instead of holding on to a gear? not sure.
how come your engine is so damn quiet that I can't hear it at all?
I haven't tried turning off O/D yet, because if I'm not mistaken, wouldn't that keep the transmission from shifting into 4th gear?
It seems as if it down shifts to 3rd then back up to 4th real quick.
Turn up your speakers and you will probably still won't hear it, but as least your will hear all the clunking from the suspension.
Update:
I turned overdrive off and the problem doesn't exist, probably because it doesn't shift to 4th. Could old differential fluid be causing this?
