Originally Posted by LostCadillacTech
thanks for the help - i downloaded a manual which has the shim math work - AND of COURSE it has to be the #5 cyl on the back wall - working asll my toyota dealer "connections" to see if i can borrow those tools -
do those lifters have any issues? - are they solid or hydraulic? possible i have a collapsed one? cause i still have compression , its just off from the rest so i dont think the valves are wasted (hopefully) but im hoping the shim thing works....
thanks
i'm not a mechanic, so can't really tell what else is going on. gen3 & 4 toyota lifters are solid not hydraulic, and rest is something like a spring loaded bucket or whatever.
You shouldn't have much problem with it since you are mechanical professionally. it's just time consuming process, I'm sure you will do the valve adjustment job right.
have you ruled out a blown Head Gasket around cylinder #5 ? how is compression on rear bank cylinders looking when compared to front bank ones ?
any significant difference as well ?
any white smoke from exhaust or buttery sediment under oil filler cap, boiling coolant maybe ?
just shooting some ideas. good luck!
