Help! Noticed a issue (maybe) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-01-2010, 06:13 PM   #1 (permalink)
Gameroom cash: $108813
View Slaz's92Camry's Photo Gallery
3rd Generation Help! Noticed a issue (maybe)
So I was on the highway doing about 60/65 n let off the gas to exit n my RPMs went down like normal but then they started jumping in-between 1&2000 it was kinda like I was tapping the gas lightly (which I wasn't)
Any thoughts as to way this is and if it's a potential problem?
Thanks- Slaz
Slaz's92Camry is offline   Reply With Quote
Old 12-01-2010, 06:34 PM   #2 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
When was the last time you checked the transmission fluid level? I'm assuming it's an automatic.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is online now   Reply With Quote
Old 12-01-2010, 07:05 PM   #3 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
I just had this problem on my XLE. It ended up being the alternator belt wasnt tight causing the battery to loose voltage and it messed with the Tach signal in the distributor. It also mis-fired when throttle was applied.
The tach signal is sent from the distributor, so maybe you just had a little glitch or something. If its running fine I wouldn't worry too much.
Old 12-01-2010, 07:10 PM   #4 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
I believe I'm experiencing this problem also. Would these symptoms exist when the transmission is over filled or under filled?
edit:
Abnormal Power Loss
Here is my thread w/ video describing my problem. Sorry if I am thread jacking.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 12-01-2010, 07:13 PM   #5 (permalink)
The transmission speed is controlled by a Sensor that has a gear shaft that is spun by the differential. The only electrical part on the entire speed section is the Pickup on the top of the sensor that detects how fast the gear is spinning (Speed).
The RPM is controlled electronically inside of the distributor (Tach Signal)
Transmission fluid level would not affect the RPM (Tach)
One thing you could try is to make sure the ignitor plug is tight. Try removing it and putting a dab of dielectric grease on the pins. Also do this on the ECU. Pull the connections apart, apply a dab of the grease on the plug and re-install.
Old 12-01-2010, 08:32 PM   #6 (permalink)
Yea my fluid is good and how should I check the distributor?
