DIY How in change your shift boot (Gen 4) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-01-2010, 10:18 PM   #1 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $589157
iTrader Score: 7 reviews
View xpeed's Photo Gallery
4th Generation DIY How in change your shift boot (Gen 4)
Since I couldn't find one on how to change your shift boot, I thought I do one. Not that hard, takes only 10 minutes, but it does take more than thirty minutes if you need to sew it onto the existing shift boot frame if you want a flush fit.
Onto the DIY
Tools needed:
Flathead Screwdriver (tape the head to prevent cracking, scuffs, and scratching)
Sewing needle
Sewing Thread
Patience
Before installation
To take the cover off, slide the flat head screw driver in the gap at the spot where the arrow is pointing. Don't jimmy or force it out. Slowly, start pulling the cover out by lifting under the cover where the boot is (where the top arrow is pointing) while pushing the screwdriver up slowly. This will help unlock the clips that are caught on the holds. After you pulled half of it out, start pulling it towards you. This will free the cover completely for you.
As you can see, it's pretty much easy from here on. Just take the old boot out and put in the new.
But wait, it doesn't seem to sit flush and looks weird. This is where it gets tricky. Remember the old boot you took out? Don't throw it away. You will need the metal frame that supports the boot cover.
The old boot cover is simply just sewed around the metal frame giving it support and helping it sit flush with the cover on. You will need to cut the frame out to use it for your new cover (if it didn't come with a frame). Once you taken it out, in the same pattern, start sewing your new boot around the metal frame. (Sew it in one direction and then go the other direction for each side. This gives it a rigid support and prevents the boot from moving around the frame too much.
Depending on the material you have, it could be easy or harder. I bought a suede cover so it was extra hard to pierce the material. This is where patience comes. If you have a sewing machine that can do it, go for it. Remember. Real men sew their own crap! This is how mine looked after I was done. Not perfect but it won't be showing as the cover will cover your embroidery.
Now that you got some support for your boot and looks awesome! So go on and place it back in there. Just put the cover back the way you took it out. Push it in first and then snap it back in place. You might have to arrange the boot a bit to make it sit flush inside.
There you have it! The finished piece. It looks great and hey, you might of picked up a new hobby in sewing too!
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
The Following 2 Users Say Thank You to xpeed For This Useful Post:
Chris Crash (12-01-2010), peshwa (12-02-2010)
Old 12-01-2010, 10:25 PM   #2 (permalink)
quangtran89's Avatar
iTrader Score: 8 reviews
View quangtran89's Photo Gallery
Nicely done!
Look like the same shift boot I have. Did you buy it off eBay?
quangtran89 is offline   Reply With Quote
Old 12-01-2010, 10:34 PM   #3 (permalink)
TN の がしょう
xpeed's Avatar
^ haha yeah, I think it is the same.
Old 12-01-2010, 10:41 PM   #4 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
Try doing this with the leather TRD boot I got...
Chris Crash is online now   Reply With Quote
Old 12-01-2010, 10:52 PM   #5 (permalink)
dorifuto.boi's Avatar
Gameroom cash: $171700
View dorifuto.boi's Photo Gallery
instead of using a screwdriver, since its a manual, u can just stick your fingers between the boot and the trim where they meet up and pull the trim up that way
http://web.ics.purdue.edu/~dfung/car.html
^^^ List of my mods
dorifuto.boi is offline   Reply With Quote
Old 12-01-2010, 11:07 PM   #6 (permalink)
Yep. That's the way I get it.
Old 12-01-2010, 11:30 PM   #7 (permalink)
TN の がしょう
xpeed's Avatar
I know, but this is a safer way to go if you don't want any of your clips to snap, especially if it's more than 13 years old.
Old 12-02-2010, 08:47 AM   #8 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
cool write up, looks good!
Old 12-02-2010, 09:15 AM   #9 (permalink)
Camry Expert/MR2 JR Xpert
jtex2717's Avatar
Gameroom cash: $272115
View jtex2717's Photo Gallery
Nice wrote up....Def looks clean....I would just get a couple of boots and find some frames in the junk yard and then they will be like a quick change boot....lmao....esp bcuz a lot of people change up their shift knobs more than they change their skivvies....
Finally Red MKII MR2 5s & Metallic Blue 96 Cam 1MZ
Watch out for the build thread!!!
IM BAAAAAACK!!!!!!!
jtex2717 is offline   Reply With Quote
Old 12-02-2010, 10:21 AM   #10 (permalink)
TN の がしょう
xpeed's Avatar
Haha, that is a good idea actually.
Old 12-02-2010, 10:26 AM   #11 (permalink)
I can never ever find boot frames in junkyards. Anyone else have this problem?
Old 12-02-2010, 11:32 AM   #12 (permalink)
A camry n00b
peshwa's Avatar
Gameroom cash: $257859
View peshwa's Photo Gallery
I guess the boot frame is specific to the manual trans only. Till date I havent found any manual trans at Pick n Pull. I kind of agree with Chris, it would be hard to find.
1995 Camry DX L4 178,6XX miles and counting each mile.... acquired 05/25/2007 at 129K miles
2004 Mazda6 I4 5-Speed Manual 115,500 miles acquired 01/21/2011 at 109,XXX miles
peshwa is offline   Reply With Quote
Old 12-02-2010, 11:37 AM   #13 (permalink)
you could probably make your own with some really thick solid steel wire.. it just has to be pretty much rectangular and the same size.
actually i think the frame is supposed to be clipped onto the bottom of the trim. because mine is. my trim and boot pulls out at the same time.
^^^ List of my mods
Old 12-02-2010, 11:58 AM   #14 (permalink)
jtex2717's Avatar
Yeah mine is too.
If you look at the Gen 3 & 3.5 Stock boot, there are plastic tabs that were used to lock the boot onto the trim. These break when replacing the boot bcuz the boot & trim seem to be one piece...
IM BAAAAAACK!!!!!!!
Old 12-02-2010, 06:29 PM   #15 (permalink)
TN の がしょう
xpeed's Avatar
I didn't see any tabs for the boot so i guess it's different for the Gen 4-4.5s
