my1999solara - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-02-2010, 12:55 PM   #1 (permalink)
View johnlalonde's Photo Gallery
Canada my1999solara
Just new at this.When I start my car v-6, it idles at 1500 hundred rpms but won't drop down for 10 mins. or so or until the temp. gauge starts to climb.Toyota says its normal. I beg to differ. Anyone experiance this problem. Only when car is cold. Restart car when still hot and the rpm drops to 900.???
johnlalonde is offline   Reply With Quote
Old 12-02-2010, 01:38 PM   #2 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Normal for the ECU to idle the engine higher to have it warm up to operating temperatures faster.
If you are still concerned;
Thermostat may not be fully closed, or at wrong temp. The water temperature sensor resistance and response should be checked out.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 12-02-2010, 01:45 PM   #3 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
Normal. Why would you beg to differ?
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 12-02-2010, 03:18 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
normal. in Winter cold mornings I sometimes see initial idle at almost 1,800-2,000rpm then gradual drop as engine warms up over time.
HINT: it will warm up faster if you keep fans and heater OFF. it will warm up even faster if you start driving it gently (no more than 2,500rpm) without using fans and heating.
