Climate Control & Windows - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-02-2010, 08:27 PM   #1 (permalink)
robertoduh's Avatar
View robertoduh's Photo Gallery
Is it possible to replace the basic climate control unit with one from an XLE?
And also my windows will sometimes not go up, and my driver side door just quit altogether. when i press the button it either doesnt go or it goes after about five minutes.
help pleasee lol
robertoduh is offline   Reply With Quote
Old 12-02-2010, 08:31 PM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Yeah its possible, but you would have to get the harness plugs / wiring and wire them to the existing harness. You would also need an electronic vent actuator out of the XLE (Circulate / ouside). It would be a real pain, and unless you just swapping the entire harness over its not worth it
As far as the windows. Pull the panel apart and pull the plug on the motor. Check for voltage on each wire with a test light by pushing the switch up or down. (one side will light up). If you get voltage on both sides of the switch to the motor the motor is bad. If you do not get voltage, its a wiring issue most likely between the door and the junction box the wiring connects to. Could also be a faulty switch itself. Check for voltage running to the switch as well
Old 12-02-2010, 08:38 PM   #3 (permalink)
robertoduh's Avatar
My car is an XLE. but it got T-boned, so i lost the rims. And i have no clue or idea how and why the last guy put the basic unit in there. I guess the buttons were too much? Lol. But thanks for the reply.
Old 12-02-2010, 08:46 PM   #4 (permalink)
doesnt sound like an xle to me then. Thats a lot of work to install a manual actuating Air control (inside/outside).
does it have rear disc brakes?
Old 12-02-2010, 09:30 PM   #5 (permalink)
robertoduh's Avatar
no it doesnt. I guess the last guy just slapped on an XLE badge on it.
Old 12-02-2010, 10:06 PM   #6 (permalink)
Tech1984's Avatar
Gameroom cash: $254350
View Tech1984's Photo Gallery
I knew a shady used car manager that did that.
I'll never forget telling him one of his cars needs brakes.
His reply: "Does the MF'er stop!!!???"
Tech1984 is offline   Reply With Quote
Old 12-02-2010, 10:23 PM   #7 (permalink)
robertoduh's Avatar
Lol well im guessing the dealer put the XLE badge on, to supposedly raise it's value. When i pulled off the lot it had a loud thunking sound coming from the rear and the brakes were grinding. The quote - $1500 to fix.
Old 12-02-2010, 10:33 PM   #8 (permalink)
Lighting Specialist!
iovaykind's Avatar
Gameroom cash: $480582
iTrader Score: 8 reviews
View iovaykind's Photo Gallery
For the windows not working, replace your harness or solder in new wires.. if you open your door panel you'll see a bunch of frayed wires, that's the cause of the windows not working for five minutes or whatnot. Happened to me also, sucks in the winter when you need to close windows on command.
For the climate control, there's just way too much stuff that needs to be changed in order to switch it to XLE, so don't even bother unless you're OCD with it being electronic instead of manual for the fresh air switch.. everything else is electronic already for the different positions for air to circulate, you can hear the motor when you switch from setting to setting.
iovaykind is offline   Reply With Quote
