OBD1 Aggravation
Hey guys, I'm kind of stumped on this.
I changed out the transmission on that XLE, got it all hooked up had a problem with rough idle so I pulled the throttle body changed the IAC out with an extra i had. Started it up and it idles real good. Thats all fine and dandy. (keep in mind once warm it ran great. Shifted great, etc..)
Started driving it yesterday and noticed it started shifting really hard and wouldnt downshift. I would get up to 45mph or 50mph and apply the brakes and the rpms go really low (almost stalls). If I physically shift it into 2nd and 1st it shifts. For some reason its going into Limp mode staying in 3rd gear.
I connected the DLC and checked for codes.. I got code 41 which is TPS Signal. Prior to this i disconnected the TPS while diagnosing the idle problem thinking that may be linked to it, so i think the code came up because of that. Regardless, I changed out the TPS this morning with a known good one too. Problem still persists. There is no Transmission codes anymore. The overdrive light continuously flashes indicating that there is no problem with the DLC connected.
The transmission I installed in there was sitting for 7 years, and I didnt change out the Shift solenoids and filter upon re-installation.
The kicker is that it was shifting great and downshifting prior to removing the Throttle body to repair the IAC. I know that the VSV and the TPS are typically linked to the shifting aspect of the transmission through the computer, but I dont think that the VSV could just "Go bad" all of a sudden.
The transmission fluid is correct, there are no leaks either.
I also had a suspicion that I may have had a problem with the kickdown cable since I removed both cables from the TB. Seems to be in working order. The Drive light doesn't come on in the cabin of the camry, but the bulb is bad and thats why. All the other lights show up now that I put the new NSS in there.
Sorry for all this text , but more information helps people diagnose a problem
And for those who dont know what vehicle it is :
Year : 1992
Make : Toyota
Model : Camry XLE
Motor : 5sfe
Transmission : A140E (Pre-94 -- two speed sensor model)
Any ideas guys??
EDIT:
Also, the transmission is not slipping .. forgot to add that in there.
Reason: added crap at the bottom
