Starting troubles??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-05-2010, 08:59 PM   #1 (permalink)
View crc13's Photo Gallery
Well, I got in the car this morning (94 xle v6) and it turned over very slow. As if the battery was on its last leg. I took the battery out and brought it to the auto store, report was it was strong. Put the battery back in, started just fine. Went out to start it tonight, again, started very slow, like it did not want to turn over. Any suggestions??? Common problem???
crc13 is offline   Reply With Quote
Old 12-05-2010, 09:29 PM   #2 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Start with cleaning your battery terminals. That's usually the most common and easiest fix.
'07 Honda Ruckus Big Bore
Old 12-05-2010, 09:40 PM   #3 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
How old is the battery; did they charge it up? What grade oil are you using? It must be cold there!
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 12-05-2010, 10:28 PM   #4 (permalink)
battery has a sticker on it from 2007. I use castrol high mileage 10w30 oil. It is about 20 degrees here.
Old 12-06-2010, 08:01 AM   #5 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Well since it took a load alright, its in good shape.
Do like Lynch said and clean the terminals. I bet you have a lower voltage going to the starter than 12V+ due to corrosion
