1994 Camry Starter issues
I have a 1994 Camry with almost 100k miles on it. It had an Audiovox alarm installed when I bought it from the dealer, something I've always had a love-hate relationship with.
I mention the alarm because I've had some things happen which I perceived to be electrical issues. However, I've just completed a pretty comprehensive check and didn't find anything out of the ordinary.
The issue of the day begins this way: my wife started the car (she mentioned it had a strange start), drove it a couple of miles, then went into a store. Came back out about 10 minutes later and turned the key. Nothing happened. We keep the lights on and they were strong, so there didn't seem to be a battery issue (there was no clicking from the starter, nothing). She tried a couple of times, then gave up. I came to get her and it started right up. I went through checking ground wires, etc, thinking it was an electrical issue. Then I put everything back together after finding nothing. I started it up, it sounded like maybe the starter had a disconnect when it started because it was like the starter engaged, then disengaged, then engaged again to start it, all in less than a couple of seconds. So I drove it around the block, came back and cut it off. I let it sit less than a minute, then tried to start it. Again, nothing. The lights were strong, no starter winddown (like a low battery not quite strong enough to turn the motor very fast), no clicking from the starter, just silence. I cut the key off, tried to start again, and it started right up. I then started it about 6 times, turning it off, turning the key off, then starting again. I couldn't replicate it.
Any ideas about what to try/check next?
