Scraping noise from the rear when braking
Hi all,
I've been chasing a problem for a while now. A scraping/grinding metal to metal noise from the rear is heard when braking at very low speeds, especially in parking situations, moving back & forth slowly. The strange part is sometimes the sound is heard after the brakes are applied when the car is still moving a little back or forth from the momentum. The noise is not heard while the car is standing still & applying the brakes.
Things I have done is replaced the drums & pads, clean the contact areas, applied grease to proper locations. Any other suggestions to check for? Would a failed wheel cylinder caused the same noises heard?
Thanks.
