96' camry oil pump question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-06-2010, 09:55 PM   #1 (permalink)
View Narciss's Photo Gallery
3rd Generation 96' camry oil pump question
Is this something that i could do myself? or would i be better off taking it in to replace? have any of you guys had to replace it? what kind of damage is it going to do to my bank account?
Narciss is offline   Reply With Quote
Old 12-06-2010, 10:34 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
If you can do a complete timing job, and can deal with the possibly rust-seized exhaust bolts and remove the exhaust pipe, then you should be able to DIY the pump.
When you go in there, change the water pump and all the seals too (cam, crank, oil pump).
Why do you think it's the oil pump?
Old 12-07-2010, 04:49 AM   #3 (permalink)
i've changed the oil filter and replaced the oil pan gasket and it leaked after that still, upon further investigation the oil is coming downward on the passenger side, of the engine, and i'm assuming oil leaking from the pan doesn't go up that high...
so yeah all that stuff you said, i'm pretty novice so getting involved with the timing... it's a little more important to trust myself with it yet. i can't really afford to not have a car for too long and if i did all that stuff i'd be pretty sluggish about it lol.
Old 12-07-2010, 09:56 AM   #4 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
There are lots of DIY for timing change. Its a fairly straight setup, and the nice thing is if you get it wrong you just have to release the pressure and re-set the timing until you get it correct.
If you change the seals or gaskets on the oil pump, you might as well change the cam seal, tensioner, tensioner-spring, water pump, and timing belt if you haven't replaced them in a while.
You have to remove the timing belt anyways.. If you are going to re-use the timing belt make sure that you buy a Paint marker and mark on the Cam Pulley and Crank pulley and the belt itself where the belt sits. You have to re-install an old belt in the exact location it came off.
Old 12-07-2010, 10:10 AM   #5 (permalink)
Mr.Nutcase's Avatar
View Mr.Nutcase's Photo Gallery
Is the engine the 5SFE? or the six cylinder
Support the engine from above....(the oil pan will come off to replace the oil pump)
To remove the pump,the timing belt must come off.
I would install a new timing belt, tensioners/spring, and idler pulley..
new water pump too.
Then the oil pan.
I recommend replacing all seals
ECT,EGR,TPS,MAF,CMP,CKP,02,
Mr.Nutcase is offline   Reply With Quote
Old 12-07-2010, 08:04 PM   #6 (permalink)
Also take a mirror and flashlight and check the firewall side of the engine. Oil on these engines like to leak from the valve cover gasket area and down.
Check the PCV valve and grommet as well. If the crankcase doesn't have a slight vacuum then oil can leak more easily. Be careful, the grommet hardens with age and can break apart when you try to remove it. So use pliers, flat screwdriver and even a hook tool to help.
Old 12-07-2010, 08:09 PM   #7 (permalink)
One step at a time. You'll be an expert in no time. There are plenty of DIYs and people willing to help here.
If you can change oil and pan gasket, coolant and ATF/strainer should be within your range too. Brake pads and rotors any time soon?
Old 12-07-2010, 09:30 PM   #8 (permalink)
Gameroom cash: $117250
View ty**20's Photo Gallery
new water pump too.
Then the oil pan.
Just making sure. Is the oil pump inside the oil pan or near it? I saw a DIY video on a 5SFE and he didn't remove the oil pan to change the oil pump and gasket.
2000 Toyota Camry LE V6 IMZFE
ty**20 is offline   Reply With Quote
Old 12-07-2010, 09:53 PM   #9 (permalink)
The 5SFE oil pump is similar to a water pump, it bolts to the pump case. But the pump case is bolted to the block and part of it sits on the oil pan like V6 pumps.
When buying a 5SFE oil pump, this is what ships:
http://www.rockauto.com/catalog/moreinfo.php?pk=1810700
