i am sorry but..... please discuss manual transmission with me
is it possible for you guys to provide me with some information ? and maybe sticky this information ? i know its been covered many times before but... i dunno. wikipedia wasn't much help. or it would be nice if this info was already out there and someone can direct me to it ?
can we make a table of all the manual trans that works with 1mz-fe and 5s-fe/3s-ge ? because the next time i do a clutch job, i want to pull the tranny and get some new gearing/synchros/lsd in
Transmissions from the factory:
5s-fe 1987-1991 Camry
- s51
First Gear: 3.538:1
Second Gear: 1.960:1
Third Gear: 1.250:1
Fourth Gear: 0.945:1
Fifth Gear: 0.731:1
Final Drive: 3.736:1
5s-fe 1992-1996 Camry
- s51
First Gear: 3.538:1
Third Gear: 1.250:1
Fifth Gear: 0.731:1
Final Drive: 3.944:1
I like the idea of collecting the tranny info and stickying it.
To my knowledge:
Originally Posted by dorifuto.boi
from the factory:
5s-fe 1997-2001 Camry/Solara
- s51
5s-fe 1991-1995 MR2
- S54
3s-ge 1991-1995 MR2
- S54
3s-gte 1994-1995 (93 Optional) MR2
- E153 with Viscous Coupler Limited Slip Differential
(The MR2 E153 Transaxle used a mechanical speed sensor from 1990 until 1992. After 1992, an electric speed sensor was used in its place. Either sensor will fit into any year of the E153 Transaxle.)
edit: I'm not sure which year the LSD was optional for the E153. It may be 92. I'm also seeing conflicting info on when the 2nd gen MR2 existed.... 90-95, 91-95, etc.
'07 Honda Ruckus Big Bore TOTALED: '03 Ford Expedition Eddie Bauer 4x4 5.4L, '96 Camry LE 5S May '10: '11 Sienna V6 XLE FWD 8-pass. July '10: '06 Matrix XR Auto FWD Oct. '09: '05 RAV-4 L 4WD
also, are the internals on all the e153 (synchros, gears) exchangable with all the other e153 internals from another car ?
All E153 internals are identical no matter which car they're pulled from (of course, with the exception of the MR2 LSD). I think I've also seen MR2 guys run E53 cases with E153 internals, IIRC. Also note that the axles are possibly different in a LSD E153 versus a non-LSD E153.
oh ok cool. somehow i always thought that the internals are different because i read somewhere that the e153 on the 3s-gte mr2 have stronger synchros and also different gear ratios.
also the final drive is because of the differential right ? is the differential part of the fwd trannys ? are they the same between trannies with the same code ? (well besides the one w LSD)
^ That actually would make sense. If you've heard that, you MIGHT want to read up on it. I'm not 100% sure that they're completely identical. I should take back my previous post...
And yes final drive = differential... which is part of a transaxle. Some trannies even share fluid between the diff and tranny portions. I wish I could show you a video of a FWD tranny tear down.
S53
First Gear: 3.285
Second Gear: 2.041
Third Gear: 1.322
Fourth Gear: 1.028
Fifth Gear: 0.820
Reverse Gear: 3.153
Applications: Toyota Celica
S54
Toyota MR2 Ratios:
First Gear: 3.285:1
Third Gear: 1.322:1
Fourth Gear: 1.028:1
Fifth Gear: 0.820:1
Reverse Gear: 3.153:1
Final Drive: 4.176:1 (EU Versions have a 3.944:1 Final Drive)
hope it helps.
93 Lexus ES300 5spd I/E URSB
Reason: cleaned up spacing
S54
Toyota MR2 Ratios:
First Gear: 3.285:1
Third Gear: 1.322:1
Fifth Gear: 0.820:1
Would the LSD from a E153 fit into an E53, or no? just wondering
Apparently you can use a 3rd gen MR2 (MRS) LSD in the E53. Just something I heard. I DO know that the guts of an E153 fit into the E53 case. And apparently you CAN make hybird E53/153's... I (or you) just need to research it more.
is the 5s-fe 97-01 camry's s51's ratios the same as
S54
Toyota MR2 Ratios:
First Gear: 3.285:1
Third Gear: 1.322:1
Fifth Gear: 0.820:1
the same for all the generations of the mr2 ?
No idea, honestly. I (or you) should search around on some of the MR2 sites i'm registered on.
Just a rough outline for now. I'll update this as needed.
Reason: merged!
