Camry rear link swap 1995 3sfe sv41 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-08-2010, 11:22 PM   #1 (permalink)
gt limited's Avatar
View gt limited's Photo Gallery
hearing a funny sound knocking from the left wheel when we jack up the car the wheel was shaking cause the rear bar bushings gone bad
Me and dad just change them out and the problem solved
we had to use the corolla ae110 ones cause the original camry ones too expensive
odo
4 disc camry even thou the engine small its quick cause its not wide as the american camrys
0-60mph 9.67
3rd gear o/d off 200kmh flat
bad bar
find use for the old honda block never work under a car with jack alone
bar getting replaced
the front one work the one closer to the trailing arm...but the rear one that had the camber type bolt never work so we had to cut it and get it weld to the new bar properly
gt limited is offline   Reply With Quote
Old 12-08-2010, 11:23 PM   #2 (permalink)
gt limited's Avatar
transmission a140e
