1. Restricted air filter
2. Faulty MFI/SFI systems
• Faulty pressure regulator
• Clogged fuel return line
• Defective engine coolant temp. sensor
• Defective intake air temp. sensor
• Faulty ECM
• Faulty injector
• Faulty throttle position sensor
• MAP sensor
[MAP SENSOR INSPECTION
1. INSPECT POWER SOURCE VOLTAGE OF MAP SENSOR
(a) Disconnect the MAP sensor connector.
(b) Turn the ignition switch ON.
(c) Using a voltmeter measure the voltage between con–
nector terminals VC and E2 of the wiring harness side.
Voltage:
4.75 – 5.25 V
(d) Reconnect the MAP sensor connector.
