E53 Gear Lube, which one is safe and good?
Hi people I have a an E53 transmission with open diff and I need to buy Gear lube so my question is would Royal Purple gear max have an adverse effect on the syncros because they're brass iirc, and I've heard limited slip agents or hypoid friction modifiers something like that are bad for brass syncros. so please chime in if you have any experience with this. I live in south florida so its never lower than 35 degrees. toyota specifies GL-4 or GL-5. i think red line makes a gear lube with no slip additives, is that what i should use?? thanks
93 Celica GTS 3SGTE
91 Supra Turbo 2JZGE-T
