Originally Posted by ycartf
From installing a few of these (different brand), I would guess that your ignition key goes into a bypass module that connects to your remote starter unit. If you peel back some stuff to find it, you should find some type of little black box that the key would go in. The ones I use have a coil of wires that surround the chip area of the key and a foam block that holds the key in place when closed shut - and then the box gets screwed or cable-tied somewhere stable under there. BUT - to say that only cold weather and faulty tape allow it to fall out - that may not be the case for you. They may have just taped the key somewhere close to the ignition (which sounds like a crappy install to me). The chip has to be able to send a signal for the remote starter to successfully crank the vehicle, making the ignition system think there is an authorized key in the ignition.
This is the best answer
I was going to say exactly that, because I remember installing remote starters and having to connect the key to the bypass module. Its really quite stupid, but thats what happens with modern day electronics.
OP, If I were you I would remove the Knee Bolster under the steering column. Generally Remote starters are connected right there, just because the ignition wires are most easy to get to. Be careful when removing it not to disturb the wires too much. If you break the security wire (very very small wire) Your going to be screwed
