Check Engine Light Briefly on at Startup? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-09-2010, 10:11 PM   #1 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
Having a brain fart at the moment and can't remember if the check engine light is supposed to come on briefly after starting your engine and then go off.
My airbag, oil, battery, brake light come on and off, but not the check engine one. Can't remember if it ever did or not, and if it is, wondering if the check engine bulb is out.
Help please? Thanks!
Still driving the car in my sig.
WhiteRabbit is offline   Reply With Quote
Old 12-09-2010, 10:41 PM   #2 (permalink)
Gameroom cash: $303755
It's supposed to come on as you crank the engine and then go off shortly after the engine starts.
Mike
Old 12-09-2010, 10:42 PM   #3 (permalink)
Tech1984's Avatar
Gameroom cash: $254350
View Tech1984's Photo Gallery
As soon as the engine starts, the CEL goes out. If not, then an OBD fault has occurred.
Bin wrenchin' on the Yota's since '84
2000 Tundra SR5 4.7 Ex Cab
2010 Camry LE 2.5
Cheers!
Tech1984 is offline   Reply With Quote
Old 12-09-2010, 10:49 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
yes, CEL (as well as ALL other warning lights) is supposed to come on briefly when you turn IGN key to ON.
probably a bad bulb, you can get them from dealer, costs like $2 or so.
Old 12-13-2010, 09:32 PM   #5 (permalink)
TN's furry friend
Thanks for the quick replies.
