P0401 after seafoaming - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-10-2010, 11:26 AM   #1 (permalink)
self-proclaimed geenyus
jermyjerm's Avatar
View jermyjerm's Photo Gallery
I seafoamed my newest Camry(2001 5SFE)and almost immediately got the insufficient EGR flow code.I cleared the code and it came back,then went away,then came back to stay.Does the O2 sensor throw this code?I'm thinking I clogged it if this is the case.Maybe the EGR tube is clogged?HELP!!
jermyjerm is offline   Reply With Quote
Old 12-10-2010, 11:36 AM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
EGR valve stuck closed.
EGR Vacuum Switching Valve (VSV).
EGR VSV open circuit.
EGR valve position sensor open or short circuit.
EGR valve position sensor.
(Vacuum Switch Valve) part# 90910-12080
If you didn't physically remove the EGR it wouldnt hurt to get a new gasket and remove it completely and clean it out. The tubing could be clogged , Like you suspected
Old 12-10-2010, 12:24 PM   #3 (permalink)
1MZ powered MR2
Jason.MZW20's Avatar
Gameroom cash: $226450
View Jason.MZW20's Photo Gallery
There's no valve position sensor on the 5SFE models, only the 1MZ with the constant vacuum EGR.
The MAP sensor controls this code. Most likely some debris from the intake tract made its way into the EGR valve and clogged it more. It's usually best to remove the EGR valve and give it a good scrub down. You may even need to soak the valve in a strong solvent.
1991 Toyota MR2 V6
Ported, rebuilt 3.0L 1MZ
Fully OBDII compliant and California smog legal
Jason.MZW20 is offline   Reply With Quote
Old 12-10-2010, 12:46 PM   #4 (permalink)
I was just saying in General what the common problems for p0401 are
Old 12-10-2010, 04:46 PM   #5 (permalink)
jermyjerm's Avatar
That makes sense,I'll put this on my to-do list.Thanks!!
Old 12-10-2010, 11:19 PM   #6 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
IIRC another TN member Seafoamed and it did such a good job all the carbon crap went down the exhaust. Some of it ended up in the EGR system. I suspect this was the case. If so remove the valve and clean the pipe.
Old 12-10-2010, 11:51 PM   #7 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
not sure, but it might have been me LOL
IIRC I encountered sticky EGR valve at some point and what helped make it better (still not 100% cured afterward unfortunately) was to remove the backpressure rubber hose from the side of EGR valve and spray (like for 15 secs) the Sea Foam Deep Creep (foam spray from local Autozone) into that hole on valve body.
then leave it for 10-15 mins and start the car instantly revving it to 2,5k rpm for starters (might produce white smoke) until it warms up and then give it a few good (brief) bursts to 5k rpm. it should do it (it helped me). in my case some crap flew out of exhaust after that and car started running smoother.
that thick rubber hose needs to be twisted to sides a couple times first before it allows itself get removed by gently pulling (it sits on a barbed pipe, don't tear the hose by pulling it with monkey strength initially like I almost did, I almost ripped it apart).
this hose connects on the other end to the bottom of EGR vacuum modulator.
if that doesn't help to get the code dismissed ultimately (do a reset by pulling for 2 minutes the ECU 15A blue fuse from Main Fuse Box under hood, driver side) you will have to unbolt the valve and clean it. warning! be ready to buy new valve if things go wrong (they did for me).
also if planning to unbolt the EGR valve, buy 2 new gaskets (1 metal, 1 cork or something like it) for it and 2 new bolts 10mm head (they hold it down to exhaust pipe) from dealer ahead of time.
Old 12-11-2010, 05:52 PM   #8 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
Before ripping the EGR apart, check the EGR VSV behind the engine block. I had this same code two years ago and that 9 out of 10 time, this little switch would set off this code. I removed it and found it to be jammed up with gunk. Clean it out, made sure it work, and reinstall it. Code went away.
The VSV is shown here by the red arrow and this is looking at it from behind the right front wheel. It's held on by one 10mm bolt and has two vacuum lines and one wire plug. Clean the vacuum line too, one of them goes to the EGR and might be clog.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is online now   Reply With Quote
Old 12-11-2010, 09:10 PM   #9 (permalink)
hehe true. I think that shows Sea Foam is going it's work.
