'94 Camry 2.2L wierd noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-10-2010, 10:20 PM   #1 (permalink)
View JoeShmoe91's Photo Gallery
Question '94 Camry 2.2L wierd noise
As the weather gets colder this time of year it's been the first time I've ran my heater as i have only had the car since summer, but first of all it takes FOREVER to heat up and second, when I have my heater on and I make a turn and accelerate it makes a really super loud whine, maybe comparable to that of slowly running a cat over . I have absolutely no clue what could be wrong with it. If anyone has any legitimate ideas I would greatly appreciate hearing them!
JoeShmoe91 is offline   Reply With Quote
Old 12-10-2010, 11:03 PM   #2 (permalink)
Oh and also I forgot to mention that my transmission struggles to shift into overdrive. i usually have to toy around with a turn o/d off, go into neutral, rev a little, go back to D, and turn o/d on to try to get it to shift, if I leave it it takes about two minutes for it to shift by itself.
Old 12-10-2010, 11:22 PM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
The transmission will refuse to shift into overdrive if the coolant is below a certain temperature. So the coolant really is cold.
Old 12-10-2010, 11:24 PM   #4 (permalink)
Possibly a stuck-open thermostat. Maybe the previous owner removed the thermostat?
Whining - may be a loose belt? Does this happen more on cold mornings than warm afternoons?
Old 12-11-2010, 05:58 AM   #5 (permalink)
View tweak1029's Photo Gallery
Does the whine happen on acceleration or only when accelerating through a turn? Is the whine related to engine speed or your car's speed? I'd check to make sure there's no air in the cooling system and if that's not the problem I'd look at the water pump.
tweak1029 is offline   Reply With Quote
Old 12-11-2010, 09:06 AM   #6 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
it takes my camrys around 10 minutes sitting idleing to warm up. If I drive it at low RPMS it takes about 1 mile for it to switch into overdrive, and about 4 or 5 miles before it starts blowing heat. I would say a squeal is either
1.) A loose belt
2.) Power Steering Maxed Out (Turned all the way to one side)
Old 12-11-2010, 09:15 PM   #7 (permalink)
When you turn on the heater the fan motor draws more power. I wonder if it's the alternator belt that's loose. These engines don't have automatic tensioners, so a belt gradually loses tension with time.
You might want to get a Krikit-II gauge on Amazon to check tension. About $20. Over tightening isn't good for the engine's front main bearing either.
