How do I replace the bulb on my taillight (pass. side brake light)? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-12-2010, 02:14 PM   #1 (permalink)
2000-Avalon's Avatar
View 2000-Avalon's Photo Gallery
Hi fellas,
I have a burnt bulb on my taillight on the passanger side. The dash light came on because of it.
I've never replaced a bulb before... do I need to remove the taillight or no?
How would I replace the bulb? What kind of tools do I need and what is that number of the bulb that I need? Anything I should watch out for before I do this?
Thanks so much for the help!
2000-Avalon is offline   Reply With Quote
Old 12-12-2010, 04:59 PM   #2 (permalink)
Nobody knows this?
Old 12-12-2010, 05:25 PM   #3 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
Open the trunk. Remove the black plastic cover over the corner. Remove the carpet if there's any there (can't remember). Grab the bulb, turn and pull out. I THINK it's 1157. But just go to Advance or AutoZone, pull the bulb out in the parking lot, bring it inside. Buy new one. Put it in.
Chris Crash is offline   Reply With Quote
Old 12-12-2010, 05:34 PM   #4 (permalink)
Thank you!
Do you remember what size socket is used to remove the plastic panel? Or do I need a philips screwdriver?
Old 12-12-2010, 05:47 PM   #5 (permalink)
I believe it's neither. There's a giant screw/hook looking thing that you just unscrew. There MIGHT be phillips head annoying plastic clips that you turn 1/4 turn then pull out on the bottom, I can't remember....
Old 12-12-2010, 05:54 PM   #6 (permalink)
Thanks again for your help!
Old 12-12-2010, 06:17 PM   #7 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $294873
View Buurin's Photo Gallery
The definitive answer:
Open the trunk. You need to undo a plastic cover. Pop some clips by unscrewing them 1/4 turn then pull. Pry back the cover by hand. Find the bulb that burned, grab the base, twist left 1/8 turn and pull. It's a 3157 bulb that pulls straight out, push straight in. That light you saw on the dash will light up if you try to put a LED bulb there. You have been warned.
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
