crank swap ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-12-2010, 03:21 PM   #1 (permalink)
Pabloso
project92camry's Avatar
View project92camry's Photo Gallery
3rd Generation crank swap ?
i dont kno if this was cover but i cant seem to find any posts on this. or maybe im typing in the wrong words.
im curious if i can swap out my 92 5sfe crankshaft for one that does not have that balance shaft big gear cause ill be removing it for my build. just wanted to know before i buy my new crank
project92camry is offline   Reply With Quote
Old 12-12-2010, 03:33 PM   #2 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
If you're removing the balance shafts, it will not make any difference if the crank has that gear or not.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 12-12-2010, 03:58 PM   #3 (permalink)
Pabloso
i kno i just hate knowing that thats there and not being used and im trying the crank as light as possible
Old 12-12-2010, 04:08 PM   #4 (permalink)
uibalnme's Avatar
Even if you do get another crank, it will have that gear. Then you'll have to pay to get it machined off. You'll be paying a small fortune to shed ~3-4lbs. Not worth it. The money would be better spent on a fully balanced rotating assembly, and port & polish work.
Old 12-12-2010, 04:18 PM   #5 (permalink)
View mrturrari's Photo Gallery
If you get a crankshaft from an MR2 or Celica 5sfe it will not have that gear and I see no reason why it wouldn't fit. Your only big worry with removing the balance shafts is to plug the holes so you maintain oil pressure.
mrturrari is offline   Reply With Quote
Old 12-12-2010, 05:05 PM   #6 (permalink)
uibalnme's Avatar
Hmm. I forgot about those. Still to pay that much for such little weight savings...not worth it IMHO. If the original crank is still within spec, I'd reuse it, and put money into other things that will actually do something for performance.
Old 12-13-2010, 12:25 AM   #7 (permalink)
Pabloso
hmm good points here guys. thx for the input. i will keep it in mind. still undecided
Old 12-13-2010, 01:06 AM   #8 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
If anything, you should be getting the balance shaft removed because they are prone to breaking; they shouldn't be removed for weight reduction...
RichieRichJP is offline   Reply With Quote
Old 12-13-2010, 01:44 AM   #9 (permalink)
Pabloso
thats another reason and so i can get a lil higher oil pressure after i plug it
Old 12-13-2010, 02:02 AM   #10 (permalink)
View 04yfz's Photo Gallery
The gears are actually pressed on, so if you're worried about a lb or two you can get it pressed off. I just kept mine but removed the balance shaft assembly.
04yfz is offline   Reply With Quote
Old 12-13-2010, 06:30 AM   #11 (permalink)
Gameroom cash: $192100
View SexieWASD's Photo Gallery
The actual ring of teeth is heated up then slides on, when it cools down it contracts and clamps itself onto the crank. It's replaced by heating it back up and sliding it off, just like you do with piston pins, only it fits more tight. I wouldn't bother with it though, it's not worth putting a torch to your crank and messing up the temperament of the metal, the actual teeth weigh next to nothing, You could then have the rest of the gear machined down once the teeth are off though, but either way it's not really worth it.
SexieWASD is offline   Reply With Quote
Old 12-13-2010, 08:49 AM   #12 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
If you get a crank with the balance gear removed, or have the balancer removed by your machinist have the machinist balance the crankshaft before installing it. Unbalanced you will see a lot of vibration at low rpm.
Old 12-13-2010, 05:50 PM   #13 (permalink)
Pabloso
ofcourse im gonna get forged rods and pistons and either redue the crank and or get a new one and balance it and match the weight of the rods and pistons. alot of work that i want to be done right.
Old 12-13-2010, 06:04 PM   #14 (permalink)
Well the crank work isn't where your going to spend the money.. the connecting rods and pistons are gonna cost you an arm and a leg.. Machine work is only going to run you like $200.00 to get it honed, balanced, and aligned
Old 12-13-2010, 06:13 PM   #15 (permalink)
Pabloso
yea i kno. money is not the problem is just hoping everything fits if i swap out the crank for like a 94+ crank or solara or celica/mr2 one
