Fuel pump not priming/turning on when ignition is switched to "on" 3vzfe - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-15-2010, 12:03 AM   #1 (permalink)
View 12340987's Photo Gallery
My 93 es300 stumbles when I start it cold. It takes 5-7 cranks and then kind runs rough for a few seconds before it smooths out. Giving it gas while starting seems to help. I think the something is wrong, and the fuel pump isn't turning on before I start the car. I thought maybe this was by design. I jumped the DLC once on a cold engine to make the fuel pump turn on and it started great on 1 or 2 cranks.
12340987 is offline   Reply With Quote
Old 12-15-2010, 03:47 AM   #2 (permalink)
1MZ powered MR2
Jason.MZW20's Avatar
Gameroom cash: $226450
View Jason.MZW20's Photo Gallery
It is by design. The fuel pump only primes when ST (start in the ignition switch) is engaged. More than likely your pump is on its way out. It's usually a sign if you have to prime the pump longer to build pressure.
If the fuel pump switch in the AFM were bad, it would start and die, then not start at all.
1991 Toyota MR2 V6
Ported, rebuilt 3.0L 1MZ
Fully OBDII compliant and California smog legal
Jason.MZW20 is offline   Reply With Quote
Old 12-15-2010, 08:51 AM   #3 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
simple way to check if your pump is going bad.
1.) Check Fuel Pressure after Fuel Filter --> To Fuel Rail.
2.) Check for 12V+ To the fuel pump
If your fuel pressure isn't within OEM Spec (Low) then you are having an issue with either a pump going bad or result or a clogged fuel filter.
Old 12-15-2010, 11:23 PM   #4 (permalink)
I asked a former ford tech and he said there is probably a check valve in the fuel pump that holds pressure while the pump is off. Is that right? If that is so, can it be repaired? Or how likely is it that it's the filter?
Old 12-16-2010, 10:57 AM   #5 (permalink)
Like I said, check the fuel pressure and let it sit for 10 minutes monitoring the pressure. If it drops, you have a leaky seal
Filter you more likely not be able to start it at all if it was plugged
Old 12-16-2010, 10:54 PM   #6 (permalink)
I don't have a fuel pressure gauge. Anybody know if a dealer or autozone will rent them?
So if it is just a check valve can it be replaced? Seems like a waste to get a whole new pump for some stupid valve that is just giving me harder starts.
