Oh no! speedometer and RPM acting weird! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-15-2010, 01:47 PM   #1 (permalink)
Died around age 230, XXX
96ToyoCam164K's Avatar
View 96ToyoCam164K's Photo Gallery
Last month I was driving and WHILE I was driving the speedometer dropped to 0. I was confused, but then it went back up with no noticeable change to the RPM.
Fast forward 2,000 miles later...I'm driving and the speedometer drops to 0, then goes back to 60 and the RPM seems to jump a bit as well. It seems to be revving thinking the car is at 0 mph. I turned the overdrive off to see if that would help, but I didn't want to leave it on so turned it off. It did it again...switched overdrive on and off. This happened this morning.
I have no idea what it is....
96ToyoCam164K is offline   Reply With Quote
Old 12-15-2010, 02:10 PM   #2 (permalink)
Tech1984's Avatar
Gameroom cash: $254350
View Tech1984's Photo Gallery
Look down there at your speed sensor connector on top of the diff. They loose connection due to being soaked in oil or corrosion. You should be getting a code. P0500
Disconnect it. Make sure it's clean and tight.
Bin wrenchin' on the Yota's since '84
2000 Tundra SR5 4.7 Ex Cab
2010 Camry LE 2.5
Cheers!
Tech1984 is offline   Reply With Quote
Old 12-15-2010, 05:45 PM   #3 (permalink)
Bingo! And whenever I change the diff. fluid its very crudey and gross under there. So, is it accesible from under the hood or would I need to climb underneath and reach over the differential?
Old 12-15-2010, 07:48 PM   #4 (permalink)
Tech1984's Avatar
Yeah, maybe get the air intake out of the way should do it
2010 Camry LE 2.5
Cheers!
Old 12-17-2010, 12:38 PM   #5 (permalink)
well, I looked on **********s and its not really showing where the sensor is located or what it looks like.
Old 12-17-2010, 12:47 PM   #6 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
^ Nope. Not allowed to say it.
'07 Honda Ruckus Big Bore
Old 12-17-2010, 12:50 PM   #7 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
the speed sensor is right on the top back side of the transmission. If you look underneath the heater hoses you should be able to see it with the airbox / piping removed
