Can I Roll the car with no axles or front brakes? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-15-2010, 08:11 PM   #1 (permalink)
View 1BADBAJA's Photo Gallery
1993 se v6 5 speed manual
I am piling the motor and was just curious if I can put the wheels back on the wheel studs with
no brakes or axle bolted to them? Just on the hubs I guess. Just want to make sure I am not
Hurting anything.
The valve cover gasket is leaking real bad and I think the
Pressure plate was not pushing the slave rod back far enough.
1BADBAJA is offline   Reply With Quote
Old 12-15-2010, 08:33 PM   #2 (permalink)
View curry.style's Photo Gallery
Yes it will roll. However, from a safety stance it isn't a good idea unless you have a known good way to stop it once it's moving.
curry.style is offline   Reply With Quote
Old 12-15-2010, 08:39 PM   #3 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
Yes you can. You can still use the parking/e brae. Though do NOT step on the brake pedal...if you do, you'll have some troubles....
I've rolled my camry without brakes before and it's not terribly unsafe. As long as you're not rolling downhill, you're fine. But I would just take the extra five minutes to bolt the 2 brake bolts back on and have brakes...The brakes didn't need to come off for the engine to come out, just the lower control arm needed to be undone. So theoretically you can re-attach the brakes and leave them on.
Chris Crash is offline   Reply With Quote
Old 12-15-2010, 08:44 PM   #4 (permalink)
Kinda what I meant....make sure the e brake works first. I was rolling a Nissan with no brakes/drivetrain downhill. I was fine because I checked the e brake first.
Old 12-15-2010, 10:14 PM   #5 (permalink)
Just rolling it a few feet. E brake works so I will use it.
Old 12-15-2010, 10:48 PM   #6 (permalink)
Gameroom cash: $114276
View reluctantmechanic's Photo Gallery
no brakes or axle bolted to them? Just on the hubs I guess. .
in order to take the axles out, you removed the lower control arm and end links...you see where I'm going with this?
reluctantmechanic is offline   Reply With Quote
Old 12-15-2010, 10:50 PM   #7 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
to physically remove the axle, all he has to do is remove the two bolts holding the struts to the hub, bang the axle out, and then reattach the two bolts to the hub
he's fine to roll the chassis without the motor and axles in
HaHa
Old 12-16-2010, 06:19 AM   #8 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Mine was rolled onto a flat bad with no brakes. Wheels mounted to the hubs. Just BE CAREFUL.
'07 Honda Ruckus Big Bore
Old 12-16-2010, 08:11 AM   #9 (permalink)
that's exactly my point
Old 12-16-2010, 02:57 PM   #10 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
You can use a large bolt and washers to keep the hub bearings in place when you move it.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
